This post asks the following question:
You are climbing a stair case. It takes n steps to reach to the top. Each time you can either climb 1 or 2 steps. In how many distinct ways can you climb to the top?
It also provides an answer:
Let $F_n$ be the number of ways to climb $n$ stairs taking only $1$ or $2$ steps. We know that $F_1 = 1$ and $F_2 = 2$. Now, consider $F_n$ for $n\ge 3$. The final step will be of size $1$ or $2$, so $F_n$ = $F_{n-1} + F_{n-2}$. This is the Fibonacci recurrence.
I don't understand the answer and here is why:
Suppose you are climbing $n$ stairs. In the end, you have to climb either $1$ stair or $2$ stairs.
If you have to climb $1$ stair, then you've already climbed $(n-1)$ stairs, which contributes $F_{n-1}$ to the recurrence. After that, you still have to climb $1$ stair, which contributes $1$ to the recurrence (there is only one way to climb the remaining one stair).
The case with $2$ remaining stairs is analogous: $F_{n-2}$ ways to climb $(n-2)$ stairs plus $2$ ways to climb the $2$ remaining stairs.
Therefore, the recurrence relation is: $F_n$ = $(F_{n-1} + 1) + (F_{n-2} + 2)$.
Can you please explain where I am wrong? More generally, I don't understand why we do not count the number of ways to climb the remaining stairs in the recurrence.
