I am trying to read Fulton-Harris's book on representation theory, specifically the first section about representations of finite groups. My question concerns Proposition 2.1, on the character of a direct sum (resp. tensor product) of representations in terms of the characters of the summands (resp. tensor factors). Namely, the character of the direct sum is the sum of the characters, and the character of the tensor product is the product of the characters.
I don't understand the proof that is given for either case. For the direct sum, it says that the eigenvalues of a fixed element $g \in G$ on $V \oplus W$ are pairwise sums of eigenvalues of $g$ on $V$ and on $W$. I believe what they meant to say is that the eigenvalues on $V \oplus W$ are given by the union of the 2 sets of eigenvalues. Assuming this is what they meant, I still don't totally understand how the corrected statement gives the result. I have the same sort of confusion about this case as I do about the tensor product, which I'll now explain...
For the tensor product, it says that the eigenvalues of $g$ on $V \otimes W$ are the pairwise products of eigenvalues of $g$ on $V$, and on $W$. I can certainly see that if $\lambda$ is an eigenvalue of $g$ on $V$, and $\delta$ is an eigenvalue of $g$ on $W$, then $\lambda \delta$ is an eigenvalue of $g$ on $V \otimes W$. However, I'm worried about the issue of (algebraic) multiplicity of the eigenvalues as roots of the characteristic polynomials:
If $\lambda$ is a root of the characteristic polynomial of $g$ on $V$ of multiplicity $e$, and $\delta$ is a root of the characteristic polynomial of $g$ on $W$ of multiplicity $f$, why is $\lambda \delta$ a root of the characteristic polynomial of $g$ on $V \otimes W$ of multiplicity $e + f$? It seems that this is what is required for the result.
Related to this, why can't there be other eigenvalues for $g$ on $V \otimes W$ aside from products of eigenvalues on the factors? It's only clear to me that the set of eigenvalues on $V \otimes W$ contains those products, but for all I know they could occur with smaller multiplicity in the characteristic polynomial, leaving room for there to be other eigenvalues.
With $V \oplus W$, it's easy to observe that the matrix for $g$ on $V \oplus W$ is simply $2 \times 2$ block diagonal with the matrices for $g$ on $V$ and on $W$ being the blocks. From this, the result on characters is immediate. We also see from this that the characteristic polynomial for $g$ on $V \oplus W$ is the product of the two characteristic polynomials, which says that eigenvalues and multiplicities must match up. However, I would like to know whether one can see this without making the observation about the shape of the matrix. Again, it is clear that the union of eigenvalues on $V$ and on $W$ is contained in the set of eigenvalues on $V \oplus W$, but why are the algebraic multiplicities what they need to be, and why couldn't there be other eigenvalues?
Lastly, if I am thinking about how to prove this result in the totally wrong way and there's an easier argument that doesn't require me to worry about these things, I'd be glad to hear it.
