Could you please suggest a proof or a reference that shows a proof of the following equality (not "passing through the densities" as done in Definition of the total variation distance: $ V(P,Q) = \frac{1}{2} \int |p-q|d\nu$?), where left-hand side and right-hand side are both used as definitions of the total variation distance between two probability measures, $P$ and $Q$? \begin{equation} \max_{A \subseteq \mathcal{A}} \left| P(A)-Q(A) \right| = \frac{1}{2} \sum_{x \in \mathcal{A}} \left| P(x) - Q(x)\right| \end{equation}
Asked
Active
Viewed 517 times
-1
2I think the proof is the same as this one which you have already seen. Just replace the densities $p, q$ with the PMFs $P$, $Q$, and replace integrals with sums. – angryavian Sep 18 '23 at 16:03
thanks angryavian! I have just found the proof by @am_rf24, from https://math.stackexchange.com/questions/3415641/total-variation-distance-l1-norm By chance, do you know any reference to a textbook or a paper? :-) – Ommo Sep 18 '23 at 16:28
I found another proof for my question (even though they use the supremum instead of the maximum): https://math.stackexchange.com/questions/3727561/total-variation-norm-of-probability-measures-related-to-l-1-norm – Ommo Sep 18 '23 at 21:39
2It is actually pretty straightforward if you are not intimidated by the look. Just realize the maximum of the left hand side is achieved only when $P(x)-Q(x)$ has the same sign for all $x\in A$, otherwise the opposite signed number cancel each other and we can achieve a larger number by cutting out the $x$ with the opposite sign. Also keep in mind the $P(x)-Q(x)$ summed over all sample space is $0$. – Hans Sep 19 '23 at 21:14
Thanks @Hans, very kind! :-) – Ommo Sep 20 '23 at 07:35
In that proof, you should use densities.. I would like to see the proof without passing through densities (if possible) ...I think I would prefer this: https://math.stackexchange.com/questions/3727561/total-variation-norm-of-probability-measures-related-to-l-1-norm – Ommo Sep 20 '23 at 16:55
I would read ``Markov Chains and Mixing Times'', second edition, by David A. Levin, Yuval Peres with contributions by Elizabeth L. Wilmer, Chapter 4. It is available online.
Did
- 21
1@Ommo is the question about more interesting/creative/what-adjective(?) proofs then, or perhaps proofs that lead to insights for a particular problem? – Did Sep 21 '23 at 00:02
Thanks for your comment Dimitros :-) I found very clear the proof & explanation provided by K. A. Buhr in "Total variation norm of probability measures related to 1 -norm?" (https://math.stackexchange.com/questions/3727561/total-variation-norm-of-probability-measures-related-to-l-1-norm). To reply to your question, i.e. "is the question about more interesting/creative/what-adjective(?) proofs ....", I do not think so :-) – Ommo Sep 21 '23 at 07:25
