27
My father recently lent me an old textbook of his, called Mathematical Methods of Physics by Mathews and Walker. I am working on the following exercise.
Consider the differential equation
$$y'' + p(x)y' + q(x)y = 0$$
on the interval $x \in [a, b]$. Suppose we know two solutions, $y_1(x)$ and $y_2(x)$, such that
$$\begin{align*} y_1(a) = 0 && y_2(a)\neq0\\ y_1(b) \neq 0 && y_2(b)=0\\ \end{align*}$$
Give the solution of the equation $$y'' + p(x)y' + q(x)y = f(x)$$ which satisfies $y(a)=y(b)=0$, in the form $$y(x) = \int_a^b G(x, s)\,f(s) \, ds$$ where $G(x, s)$, the so-called Green's function, involves only the solutions $y_1$ and $y_2$ and assumes different functional forms for $x<s$ and $s<x$.
Earlier in the chapter, the authors begin to describe the general method for solving these types of equations and leave the completion to the student. This is what I have tried so far, following their advice:
First we seek a solution of the form $$y=u_1(x)y_1(x) + u_2(x)y_2(x)$$ where the $u_i(x)$ functions are to be determined. We will need the first and second derivatives of this expression in order to solve the differential equation. Thus, $$y' = u_1y_1' + u_2y_2' + u_1'y_1 + u_2'y_2$$ Before calculating $y''$, the authors suggest to set $u_1'y_1+u_2'y_2=0$ for the sake of convenience. (Anyone have a more sophisticated reasoning for this step?) In any case, I follow suit, and thus we have $$\begin{align*} y' &= u_1y_1' + u_2y_2'\\ y'' &= u_1y_1'' + u_2y_2'' + u_1'y_1'+u_2'y_2' \end{align*}$$
At this point, I plug these representations back into the inhomogeneous equation. $$[u_1y_1'' + u_2y_2'' + u_1'y_1'+u_2'y_2'] + p(x)[u_1y_1' + u_2y_2'] + q(x)[u_1y_1+u_2y_2] = f(x)$$ Next I reorganize the equation to take advantage of the fact that $y_1$ and $y_2$ solve the homogeneous equation. $$u_1[y_1''+p(x)y_1'+q(x)y_1] + u_2[y_2''+p(x)y_2'+q(x)y_2] + u_1'y_1'+u_2'y_2'= f(x)$$ The first two terms in the sum equal zero by assumption, thus $$u_1'y_1'+u_2'y_2'= f(x)$$ We also have the following equation, by our "convenient assumption" $$u_1'y_1+u_2'y_2=0$$
Hence, $u_1'=\dfrac{-u_2'y_2}{y_1}$, which we then substitute to find $u_2'$ $$\begin{align*} \dfrac{-u_2'y_2}{y_1}y_1'+u_2'y_2'&= f(x)\\ u_2'&= \dfrac{y_1f(x)}{y_2'y_1-y_2y_1'}\\ \end{align*}$$ which gives us $u_2'$ purely in terms of the $y_i$'s and $f$, allowing us to find a similar expression for $u_1'$ $$ u_1'=-\dfrac{y_2f(x)}{y_2'y_1-y_2y_1'} $$
[EDIT: This is where I was originally stuck. The rest of the solution is as follows, courtesy comment below from @icurays1]
Finally we have our expression for $y$, $$\begin{align*} y&=-y_1\int_a^b\dfrac{y_2f(s)}{y_2'(s)y_1(s)-y_2(s)y_1'(s)}ds + y_2\int_a^b\dfrac{y_1f(s)}{y_2'(s)y_1(s)-y_2(s)y_1'(s)} ds\\ y(x)&=-\int_a^b\dfrac{y_1(x)y_2(s)f(s)}{y_2'y_1-y_2y_1'}ds + \int_a^b\dfrac{y_2(x)y_1(s)f(s)}{y_2'(s)y_1(s)-y_2(s)y_1'(s)} ds\\ \end{align*}$$ and we reach the desired form: $$y(x)=\int_a^b\dfrac{y_2(x)y_1(s)-y_1(x)y_2(s)}{y_2'y_1-y_2y_1'}f(s)ds$$
A.E
  • 2,513
    Alternate hints: the Green's function must be continuous, and the derivative will have a jump along $x=s$. – icurays1 Jul 12 '13 at 18:49
  • So I went ahead with solving for the $u_i'$'s but I can't seem to figure out how to work $s$ into the equation... Any advice? – A.E Jul 12 '13 at 21:15
  • @Orangutango I have a much simpler method of finding Green's functions, but it would be different than the method your book seems to describe. – icurays1 Jul 12 '13 at 21:18
  • Reference? I am interested. Although, I would like to still settle this problem in the manner presented. – A.E Jul 12 '13 at 21:19
    @Orangutango I'll post a brief description of the method as an answer. – icurays1 Jul 12 '13 at 21:22
  • @Amzoti I noticed you answered a more specific question involving variation of parameters. Do you know how I could turn my last line of derivation into the desired form? – A.E Jul 12 '13 at 21:42
  • @Orangutango Actually, I think your solution is complete - the $s$ comes as the integration variable in those two integrals. My method is only really faster if your operator is in Sturm-Liouville form ($py^{\prime\prime}+p^\prime y^\prime+qy$). – icurays1 Jul 12 '13 at 21:44
  • @Orangutango: See https://math.uc.edu/~halpern/diffeqns/Handouts/Variationofparametergreensfn.pdf – Amzoti Jul 12 '13 at 21:48
    OH! My issue was using $dx$ as the infinitesimal, when it really should be $ds$. – A.E Jul 12 '13 at 21:52
Well, the problem of finding the solution to $$ y'' + p(x) y' + q(x) y = f(x) $$ when the solutions $y_1$ and $y_2$ of the homogeneous problem are "known" is in some thinking, the following:
I know $y(x) = c_1 y_1(x) + c_2 y_2(x)$ solves $$ y'' + p(x) y' + q(x) y = 0. $$ What if I let $c_1$ and $c_2$ vary, in order to satisfy point by point, the non-homogeneous equation. I propose then $y(x) = c_1(x) y_1(x) + c_2(x) y_2(x)$, and see where it leads me. For that, we calculate $$ y'(x) = c_1(x) y_1'(x) + c_2(x) y_2'(x) + c_1'(x) y_1(x) + c_2'(x) y_2(x), $$ and $y''$. Before doing that, let's take a look on $y'(x)$. If we let the terms of the first derivative of $c_1$, and $c_2$ to subsist, then $y''$ will have terms of the second derivative on $c_1$ and $c_2$, and we will achieve nothing in terms of simplicity. What was a second order ODE with one unknown ($y$), will become a second order ODE with two unknowns ($c_1$ and $c_2$), with the lack of a second equation. This is why, in the construction, one asks for $$ c_1'(x) y_1(x) + c_2'(x) y_2(x) = 0. $$ If this condition is fulfilled, we achieve one very important thing: to reduce the non-homogeneous second order ODE, to a system of two first order ODEs, which, incidentally, we know how to solve exaclty (modulus integration). This would be one rational explanation in choosing the above condition.
Now back to the problem at hand. When one has initial conditions, the problem is stated in the following way: $$ y'' + p(x) y' + q(x) y = f(x), \quad y(a) = y_0, \quad y'(a) = y_0', \quad a < x < b. $$
The easiest way to solve the full problem is to take advantage of the linearity and split it in two: $$ y_h'' + p(x) y_h' + q(x) y = 0, \quad y_h(a) = y_0, \quad y_h'(a) = y_0', $$
and
$$ y_p'' + p(x) y_p' + q(x) y = f(x), \quad y_p(a) = 0, \quad y_p'(a) = 0, $$
and then $y(x) = y_h(x) + y_p(x)$. In other words, we solve the homogeneous ODE with non-homogeneous initial conditions, and then the non-homogeneous ODE with homogeneous initial conditions, treating the non-homogeneities separately.
The homogeneous solution will be $$ y_h(x) = k_1 y_1(x) + k_2 y_2(x), $$ where $y_1$ and $y_2$ are the two linearly independent solutions, and $k_1$ and $k_2$ are determined by solving the system $$ \begin{pmatrix} y_1(a) & y_2(a) \\ y_1'(a) & y_2'(a) \end{pmatrix} \begin{pmatrix} k_1 \\ k_2 \end{pmatrix} = \begin{pmatrix} y_0 \\ y_0' \end{pmatrix}. $$
For $y_p$, we propose the solution $$ y_p(x) = c_1(x) y_1(x) + c_2(x) y_2(x) $$ with the condition $c_1'(x) y_1(x) + c_2(x) y_2(x) = 0$ (explained above). Then, substituting in its ODE, we can determine $c_1(x)$ and $c_2(x)$ by solving the system $$ \begin{pmatrix} y_1(x) & y_2(x) \\ y_1'(x) & y_2'(x) \end{pmatrix} \begin{pmatrix} c_1'(x) \\ c_2'(x) \end{pmatrix} = \begin{pmatrix} 0 \\ f(x) \end{pmatrix} $$ and then \begin{align} c_1'(x) &= -\frac{y_2(x) f(x)}{W(y_1,y_1)(x)} \\ \\ c_2'(x) &= \frac{y_1(x) f(x)}{W(y_1,y_2)(x)} \end{align} where $W(y_1,y_2)(x) = y_1 y_2'- y_1' y_2$ is the Wronskian of $y_1$ and $y_2$.
The key here is that, in order to obtain $c_1$ and $c_2$, one has to integrate. To do this, we need limits of integration. Conveniently, we know the initial conditions for $y_p$; they can be read as $$ \begin{pmatrix} y_1(a) & y_2(a) \\ y_1'(a) & y_2'(a) \end{pmatrix} \begin{pmatrix} c_1(a) \\ c_2(a) \end{pmatrix} = \begin{pmatrix} 0 \\ 0 \end{pmatrix} $$ This means that $c_1(a) = c_2(a) = 0$. Finally, performing the integration, $$ \int_{a}^x c_1'(s) ds = c_1(x) = -\int_{a}^x \frac{y_2(s)}{W(s)} f(s) ds $$ $$ \int_{a}^x c_2'(s) ds = c_2(x) = \int_{a}^x \frac{y_1(s)}{W(s)} f(s) ds $$ and then $$ y_p(x) = \int_{a}^x \frac{y_1(s) y _2(x) - y_1(x)y_2(s)}{W(s)} f(s) ds $$ or $$ y_p(x) = \int_{a}^{b} g(x,s) f(s) ds $$ where $$ g(x,s) = \begin{cases} \frac{y_1(s) y _2(x) - y_1(x)y_2(s)}{W(s)} & \mbox{if }a < s < x \\ 0 & \mbox{if } x < s < b \end{cases} $$ Finally $$ y(x) = k_1(x) y_1(x) + k_2(x) y_2(x) + \int_a^b g(x,s) f(s) ds. $$ The function $g(x,s)$ is called Green's function, and is completely associated with the problem $$ L y = \frac{d^2 y}{d x^2} + p(x) \frac{d y}{d x} + q(x) y = f(x), \quad B y = \begin{pmatrix} y(a) \\ y'(a) \end{pmatrix} = \begin{pmatrix} 0 \\ 0 \end{pmatrix}, \quad a < x < b $$
The Green's functions is some sort of "inverse" of the operator $L$ with boundary conditions $B$.
What happens with boundary conditions on $a$ and $b$?
Well, in this case, the boundary conditions $B$ are of the form $$ By = \begin{pmatrix} \alpha_1 y(a) + \beta_1 y'(a) + \gamma_1 y(b) + \delta_1 y'(b) \\ \alpha_2 y(a) + \beta_2 y'(a) + \gamma_2 y(b) + \delta_2 y'(b) \end{pmatrix} $$ and need not to be homogeneous, i.e. $B y = (r_1, r_2)^T$. If the boundary conditions are linearly independent, then the problem is well defined, and we have to solve $$ L y = f(x), \quad B y = (r_1, r_2)^T, \quad a < x < b. $$ The case where $\alpha_2 = \beta_1 = \gamma_{1,2} = \delta_{1,2} = 0$ is the well known initial condition problem, solved above. The case $\gamma_1 = \delta_1 = \alpha_2 = \beta_2 = 0$ is called unmixed, while the other is mixed. Examples of unmixed boundary conditions are Dirichlet conditions $y(a) = y(b) = 0$, Neumann conditions $y'(a) = y'(b)$ and Robin conditions $y(a) + \alpha y'(a) = y(b) + \beta y'(b) = 0$. Examples of mixed boundary conditions are periodic $y(a) = y(b)$, $y'(a) = y'(b)$, and antiperiodic $y(a) = -y(b)$, $y'(a) = -y'(b)$.
As with initial conditions, the best way to work is to split the problem in two: $$ L y_h = 0, \quad B y_h = (r_1, r_2)^T $$ and $$ L y_p = f(x), \quad B y_p = (0, 0)^T $$ Solving for $y_h$ is equivalent for all types of boundary conditions, and I'll ignore this problem (if you have doubts is a good exercise to work out the details yourself).
Unmixed boundary conditions
$$ B y = \begin{pmatrix} B_1 y \\ B_2 y \end{pmatrix} = \begin{pmatrix} \alpha_1 y(a) + \beta_1 y'(a) \\ \gamma_2 y(b) + \delta_2 y'(b) \end{pmatrix} = 0 $$
Let $w_1(x) = h_{11} y_1(x) + h_{22} y_2(x)$, and $w_2(x) = h_{12} y_1(x) + h_{22} y_2(x)$ with $h_{ij}$ constants, such that $B_1 w_1 = 0$ and $B_2 w_2 = 0$. We propose $$ y_p(x) = c_1(x) w_1(x) + c_2(x) w_2(x) $$ with the (very natural) condition $c_1'(x) w_1(x) + c_2'(x) w_2(x) = 0$. As in the initial conditions problem, it's easy to see that \begin{align} c_1'(x) &= -\frac{w_2(x) f(x)}{W(w_1,w_2)(x)}\\ \\ c_2'(x) &= \frac{w_1(x) f(x)}{W(w_1,w_2)(x)} \end{align} where $W(w_1,w_2)(x) = W(x)$ is the Wronskian of $w_1$ and $w_2$. To determine the limits of integration, we simply evaluate the boundary condtions: \begin{align} B_1 y_p &= c_1(a) B_1 w_1 + c_2(a) B_1 w_2 = c_2(a) B_1 w_2 = 0\\ B_2 y_p &= c_1(b) B_2 w_1 + c_2(b) B_2 w_2 = c_1(b) B_2 w_1 = 0 \end{align} This relation tells us that $c_1$ and $c_2$ need to fulfill the conditions $c_2(a) = c_1(b) = 0$, in order to satisfy the boundary conditions. Then $$ \int_x^b c_1'(s) ds = - c_1(x) = \int_x^b \frac{w_2(s)}{W(s)}f(s) ds $$ and $$ \int_a^x c_2(s) ds = c_2(x) = \int_a^x \frac{w_1(s)}{W(s)}f(s) ds $$ Finally $$ y_p(x) = \int_x^b \frac{w_1(x)w_2(s)}{W(s)} f(s) ds + \int_a^x \frac{w_2(x) w_1(s)}{W(s)} f(s) ds $$ or $$ y_p(s) = \int_a^b g(x,s) f(s) ds $$ where $$ g(x,s) = \begin{cases} \frac{w_1(s) w_2(x)}{W(s)} & \mbox{if } a < s < x < b\\ \\ \frac{w_1(x) w_2(s)}{W(s)} & \mbox{if } a < x < s < b\end{cases} $$
Mixed boundary conditions
The easiest way here would be to use the result above. Let $$ y_1(x) = c_{11}(x) w_{11}(x) + c_{12}(x) w_{12}(x) $$ and $$ y_2(x) = c_{21}(x) w_{21}(x) + c_{22}(x) w_{22}(x) $$ where $w_{11}$, $w_{12}$, $w_{21}$, $w_{22}$, are chosen in order to fulfill $$ B_1 y_1 = \begin{pmatrix} \alpha_1 y_1(a) + \beta_1 y_1'(a) \\ \gamma_2 y_1(b) + \delta_2 y_1'(b)\end{pmatrix} = 0 $$ and $$ B_2 y_2 = \begin{pmatrix} \gamma_1 y_2(b) + \delta_1 y_2'(b) \\ \alpha_2 y_2(a) + \beta_2 y_2'(a)\end{pmatrix} = 0 $$
By construction, let \begin{align} y_1(x) &= \frac{1}{2}\int_a^b g_1(x,s) f(s) ds\\ \\ y_2(x) &= \frac{1}{2}\int_a^b g_2(x,s) f(s) ds \end{align} where \begin{align} g_1(x,s) &= \begin{cases} \frac{w_{11}(s) w_{12}(x)}{W(s)} & \mbox{if } a < s < x < b\\ \\ \frac{w_{11}(x) w_{12}(s)}{W(s)} & \mbox{if } a < x < s < b\end{cases} \\ \\ g_2(x,s) &= \begin{cases} \frac{w_{21}(s) w_{22}(x)}{W(s)} & \mbox{if } a < s < x < b\\ \\ \frac{w_{21}(x) w_{22}(s)}{W(s)} & \mbox{if } a < x < s < b\end{cases} \end{align} Then, taking $y(x) = y_h(x) + y_1(x) + y_2(x)$, where $y_h(x) = k_1 y_1(x) + k_2 y_2(x)$, we have $$ L y = L y_h + L y_1 + L y_2 = L y_1 + L y_2 = \frac{1}{2}f(x) + \frac{1}{2}f(x) = f(x) $$ and \begin{align} B y &= B y_h + B y_1 + B y_2 \\ &= B y_h + B_1 y_1 + B_1 y_2 + B_2 y_1 + B_2 y_2 \\ &= B y_h + B_2 y_1 + B_1 y_2 = \begin{pmatrix} r_1 \\ r_2 \end{pmatrix} \end{align} If we choose $k_1$ and $k_2$ in such way that $$ B y_h = \begin{pmatrix} r_1 \\ r_2 \end{pmatrix} - B_2 y_1 - B_1 y_2 $$ then $$ y(x) = y_h(x) + y_1(x) + y_2(x) = y_h(x) + \int_a^b g(x,s) f(s) ds $$ where $$ g(x,s) = \begin{cases} \frac{w_{11}(s) w_{12}(x) + w_{21}(s) w_{22}(x)}{2 W(s)} & \mbox{if } a < s < x < b\\ \\ \frac{w_{11}(x) w_{12}(s) + w_{21}(x) w_{22}(s)}{2W(s)} & \mbox{if } a < x < s < b\end{cases} $$
A very thorough treatment of the construction of Green's functions for second order ODEs can be found in the fantastic book Principles and Techniques of Applied Mathematics, by Bernard Friedman.
Pragabhava
  • 4,941
