Let A be a nxn matrix, x be a nx1 matrix and 0 be a nx1 zero matrix.
Ax=0
a)If A is invertible, solve the homogeneous system of linear equations
b)Is Ax = 0 always consistent? Explain
Can anyone start me off how to go about to solving this? I am not too sure about a)
For b), I wrote Yes as a homogeneous equation is always consistent.There is always a solution of x=0, hence it will always be consistent.Am I right?
    For part a, start with the definition of a matrix inverse. Think how you can use that definition, and you can always do the same thing to both sides of an equation. – Golden_Ratio Jan 22 '22 at 08:53
  • @Golden_Ratio so mutiplying A^-1 to both sides , x will still be equal to 0. Thats the answer? – c00kie132 Jan 22 '22 at 10:21
a) If A is invertible, it means that $Ax = 0$, for $x$ only has $0$ for the answer.
You can use gaussian elimination or inverse matrix to solve it.
$Ax = 0$
$A^{-1}Ax = A^{-1}×0$
$x = 0$
b) Of course $Ax = 0$ always has the answer, and that is $0$.
Reference
$A$ is invertible matrix iff $Ax=0$ has the trivial solution only.
jackson
  • 33
