Suppose $P$ is a $n \times n$ projection matrix with two eigenvalues equal to one. Is it true that and how can I show that $$ (I-\nu P)^m \to (I-P), \quad for \ m \to \infty, $$ with $0 < \nu < 1$.
My attempt: Let $P=ODO^T$ be an eigendecomposition with $OO^T=I$ and $D=diag(d_1, \dots, d_n)$ where $d_1=d_2=1$ and $d_k=0 \ (k=3, \dots, n)$. Then $$ (I-\nu P)^m = O(I-\nu D)^mO^T=Odiag((1-\nu d_k)^m)O^T $$ For $k=1, 2$, $(1-\nu d_k)^m \to 0$ and for $k=3, \dots, n$, $(1-\nu d_k)^m = 1$. Since those are the eigenvalues of the orthogonal complement $I-P$, the claim follows.
Is my reasoning correct?
    Seems reasonable to me. As you can tell, the claim is independent of how many of the eigenvalues are one and how many are zero (see also my answer). – parsiad Mar 11 '19 at 14:59
  • For future reference, you can use \operatorname{diag}(x) for $\operatorname{diag}(x)$. – parsiad Mar 13 '19 at 06:02
Using the fact that projection matrices are idempotent (i.e., $P^2=P$) and the binomial theorem, $$ \left(I-vP\right)^{m}=\sum_{k=0}^{m}\binom{m}{k}\left(-vP\right)^{k}=I+P\sum_{k=1}^{m}\binom{m}{k}\left(-v\right)^{k}=I-P+P\left(1-v\right)^{m}\rightarrow I-P. $$
parsiad
  • 25,738
  • One follow-up, does this also imply: $||(I-\nu P)^m f||_2^2 \to ||(I-P)f||_2^2$ where $||.||_2^2$ is the Euclidean norm and $f$ is some real-valued vector? – user483161 Mar 12 '19 at 11:42
    If $g$ is a continuous function and $x_n \rightarrow x$, then $g(x_n) \rightarrow x$ (this fact is also known as limits and continuous functions commute). In your case, $g(x) = \Vert x f \Vert_2^2$ and $x_n = (I - v P)^n$. In short, yes, your claim is true. – parsiad Mar 13 '19 at 01:22
  • For future reference, you can use \Vert for $\Vert$ and \cdot for the $\cdot$ symbols. – parsiad Mar 13 '19 at 06:01
