22
The problem is:
If $G$ is a finite group with order not divisible by 3, and $(ab)^3=a^3b^3$ for all $a,b\in G$, then show that $G$ is abelian.
I have been trying this for a long time but not been able to make any progress. The only thing that I can think of is: $$ab\cdot ab\cdot ab=aaa\cdot bbb\implies(ba)^2=a^2b^2=aabb=(\text{TPT})abba.$$ Now, how can I prove the last equality? If I write $aabb=abb^{-1}abb$, then in order for the hypothesis to be correct, $b^{-1}abb=ba\implies ab^2=b^2a$. Where am I going wrong? What should I do?
Parcly Taxel
  • 105,904
  • Suppose that $x\in G$ satisfies $ x^3=e$. Then we cannot have $x\ne e$, otherwise $x$ would have order 3, which implies that 3 divides $|G|$ (recall that the order of a group element divides the order of the group). Hence, $$\forall x\in G:\quad x^3=e~\Longrightarrow~x=e,$$ and as $(ab)^3=a^3b^3$ for all $ a,b \in G $, we see that the function $\phi:G\to G$ defined by $$\forall x\in G:\quad\phi(x) \stackrel{\text{def}}{=} x^3$$ is an injective group homomorphism.
  • Now, $$\forall a,b\in G:\quad ababab=(ab)^3=a^3b^3=aaabbb.$$ Hence, $$\forall a,b\in G:\quad baba=aabb,\quad\text{or equivalently},\quad (ba)^2=a^2b^2.$$ Using this fact, we obtain \begin{align} \forall a,b\in G:\quad(ab)^4&= [(ab)^2]^2\\ &=[b^2a^2]^2\\ &=(a^2)^2(b^2)^2\\ &=a^4b^4\\ &=aaaabbbb. \end{align}
  • On the other hand, \begin{align} \forall a,b\in G:\quad(ab)^4&= abababab\\ &=a (ba)^3b\\ &=ab^3a^3b\\ &=abbbaaab. \end{align}
  • Hence, for all $a,b\in G$, we have $aaaabbbb=abbbaaab$, which yields $$\phi(ab)=a^3b^3=b^3a^3=\phi(ba).$$ As $\phi$ is injective, we conclude that $ab=ba$ for all $a,b\in G$.
Conclusion: $G$ is an abelian group.
Parcly Taxel
  • 105,904
Haskell Curry
  • 20,144
  • Thanks a lot for the solution. But how can you say that $\phi(x)=x^3$ is injective? –  Jan 21 '13 at 06:44
  • What was your motivation for considering $(ab)^4$? It is a bit arbitrary for me. –  Jan 21 '13 at 06:46
    Got it! $x^3=y^3 \implies x^3(y^{-1})^3\implies (xy^{-1})^3=e\implies x=y$ –  Jan 21 '13 at 06:59
    @ramanujan_dirac: Hi Ramanujan. There is an even easier way to show that $ \phi $ is injective. First use the property $ \forall a,b \in G: ~ (ab)^{3} = a^{3} b^{3} $ to prove that $ \phi $ is a group homomorphism. Then use the fact that $ \forall x \in G: ~ x^{3} = e \Longrightarrow x = e $ to deduce that $ \ker(\phi) = { e } $. It follows immediately that $ \phi $ is injective. My consideration of $ (ab)^{4} $ was an attempt to play around with identities to see what I could get. My goal was to somehow obtain $ \forall a,b \in G: ~ (ab)^{3} = (ba)^{3} $. – Haskell Curry Jan 21 '13 at 20:53
11
The way, I am writing here, is from my old notes and personally I prefer the other approaches. But, maybe the given additional points below, inspire you for other problems like this problem.
We can prove that if for an integer $n$ and every $a,b\in G$, $(ab)^n=a^nb^n$, then $$(aba^{-1}b^{-1})^{n(n-1)}=e$$ The proof is easy. In fact, $$(aba^{-1}b^{-1})^{n^2}=[(aba^{-1}b^{-1})^n]^n=[a^n(ba^{-1}b^{-1})^n]^n=\cdots^*=a^nb^na^{-n}b^{-n}\\\ (aba^{-1}b^{-1})^{n}=(ab)^n(a^{-1}b^{-1})^n=a^nb^na^{-n}b^{-n}$$ *refer here for the missing steps
In your problem, we assume $G$ is not abelian, so there exist $a,b\in G, aba^{-1}b^{-1}\neq e$. According to the above lemma $$(aba^{-1}b^{-1})^6=e$$ since we know $(ab)^3=a^3b^3$. So $|aba^{-1}b^{-1}|\big| 6$ and because of $3\nmid|G|$ so $|aba^{-1}b^{-1}|=2$. This means that $(aba^{-1}b^{-1})^2=e$. On the other hand, $$(ab)^3=a^3b^3\Longrightarrow (ba)^2=a^2b^2$$ (see @Haskell's answer) then $(a^{-1}b^{-1})^2(ab)^2=e$ or $(ab)^2=(ba)^2=a^2b^2$ or $ab=ba$. A nice contradiction!
Parcly Taxel
  • 105,904
Mikasa
  • 67,942
8
Hints (remember: $\,|G|<\infty\,\,\,and\,\,\,3\,\nmid\, |G|\,$): $\,\,\forall\,\,a,b\in G\,$
$$\begin{align*}(1)&\;\;\;\text{Show that}\,\,\,\,(ba)^2=a^2b^2\\{}\\(2)&\;\;\;\text{Prove that}\;\;f:G\to G\,\,\,,\,\,f(x):=x^3\,\,,\,\,\text{is an isomorphism}\\{}\\(3)&\;\;\;\text{Define}\,\,z:=\left(aba^{-1}\right)^3 \longrightarrow \begin{cases}z=ab^3a^{-1},\;\;\;\text{and also}\\{}\\z=f(a)f(b)f(a^{-1})=a^3b^3a^{-3}\end{cases}\\{}\\(4)&\;\;\;\text{Using(2)-(3) , show that}\;\;a^2\in Z(G)\Longleftrightarrow a^2g=ga^2\,\,,\,\forall\,g\in G\\{}\\(5)&\;\;\;\text{Finally, use (1) to show that}\,\,\,ab=ba\end{align*}$$
DonAntonio
  • 214,715
    For (3,(4)) you could use: $(ab)^2=b^2a^2\Rightarrow a^3b^3=(ab)^3=(ab)(ab)^2=ab^3a^2\Rightarrow a^2b^3=b^3a^2$. – P.. Jan 20 '13 at 10:05
  • Good one, @Pambos: easier your way. +1 – DonAntonio Jan 20 '13 at 10:12
  • @DonAntonio: I haven't been able to prove $a^2g=ga^2$, From 2, 3, and also by Pambos' comment I have proved that $a^2b^3=b^3a^2$, but how can we substitute $b^3$ by $g$. Aren't we assuming that any element can be written as the cube of another? Thanks. –  Jan 22 '13 at 02:20
    Well, since by (2) we know that $,f,$ is surjective, then $,\forall,x\in G,,\exists,g_x\in G,,s.t.,,x=g_x^3,$ , so by what you've proved $,a^2x=xa^2,,\forall,,x\in G\Longleftrightarrow a^2\in Z(G),$ ... – DonAntonio Jan 22 '13 at 02:44
