I know I'm going wrong somewhere just not sure where
I haven't used Bayes' theorem much before so any help would be greatly appreciated.
Suppose you are given following data.
$5\%$ of the population have heart disease.
If you have heart disease, the probability that you have high blood pressure is $90\%$
If you do not have heart disease, the probability that you have high blood pressure is $15\%$
What is the probability that a person chosen at random from the population has high blood pressure?
$$P(B) = P(B|H)P(H) + P(B|H')P(H')$$
$$P(B) = (.9)(.05) + (.15)(.95) = .1875$$
Using Bayes Theorem calculate the probability that the person has heart disease, if they have high blood pressure.
$$P(H|B) = \frac{P(B|H)P(H)}{P(B)}$$
$$(.9)(.05)/.1875 = .24$$
Using Bayes Theorem calculate the probability that the person has heart disease, if they do not have high blood pressure.
$$P(H|B') = \frac{P(B'|H)P(B')}{P(H)}$$
When I sub in for this part I'm getting an invalid answer
Nikos M.
  • 2,326
    There is no reason to use boldfaced characters. – Taroccoesbrocco May 12 '18 at 13:21
  • Welcome to stackexchange. Here's a way to do the problem that may provide more intuition than Bayes Theorem (it is that theorem, in disguise - you can use it to check your work) https://math.stackexchange.com/questions/2279851/applied-probability-bayes-theorem/2279888#2279888 – Ethan Bolker May 12 '18 at 13:22
The answer is $\frac{3}{16}.$
You divide and conquer, so the probability that someone has heart disease and high blood pressure is $(\frac{1}{20}) (\frac{9}{10})$, which is $\frac{9}{200}$. The probability that someone doesn't have heart disease and has high blood pressure is $(\frac{1}{20}) \frac{3}{20}$, which is $\frac{57}{400}$. $\frac{9}{200}$ is the same as $\frac{18}{400}$. If you add these two fractions, you get $\frac{75}{400}$, or $\frac{3}{16}$.
tien lee
  • 1,831
PotatoLatte
  • 273
  • 14
$$P(H|B) = {P(H \land B) \over P(B)}={P(B|H)P(H) \over P(B)}$$ for the second is fine.
So analogously for the third $$P(H|B') = {P(H \land B')\over P(B')} = {P(B'|H)P(H) \over P(B')}$$
and use that $P(B') = 1-P(B)$ and $P(B'|H) = 1- P(B|H)$. You know all the values already.
Henno Brandsma
  • 250,824
The reason why you got an incorrect answer for the 3rd sub-part is because of the incorrect implementation of the Bayes rule.
Your RHS gives $P(B'|H)$ which can be calculated as $1-P(B|H)=1-0.9=0.1$
Here $P(H|B')=\frac{P(H)P(B'|H)}{P(B')} = \frac{P(H).[1-P(B|H)]}{1-P(B)} = \frac{0.05*0.1}{0.8125} = \frac{50}{8125}=0.0061$
