I've just finished writing a a linear programming problem solver which uses the simplex method. Now I would like to start optimizing my solver but before I can do this, I need a way of reliably testing it's performance.
What is a good algorithm for generating random linear programming problems of arbitrary size? If possible I would also like to be able to control whether a solution exists or not and I would like to ensure that the origin is a vertex on the simplex.
martega
  • 281
If you want a given vector $v \in {\mathbb R}^n$ as a solution:
  1. take a random $m \times n$ matrix $A$
  2. choose a vector $b \in{\mathbb R}^m$ such that $b \ge A v$.
    You can generate b by taking $b=Av+\delta, \delta_i\ge0$
Then the constraints can be $A x \le b$.
Generically, if $m \ge n$ and $b - Av$ has at least $n$ zero entries, $v$ will be a basic solution.
If you want a problem that is unbounded
  1. pick vectors $u$ and $v$ with $v \ne 0$.
  2. Take a random matrix $A$. For each $j$ such that $(Av)_j > 0$, multiply row $j$ of $A$ by $-1$, so you get a matrix $A$ with $A v \le 0$.
  3. Choose $b$ such that $b \ge A u$. Then $u + t v$ satisfies the constraints $Ax \le b$ for all $t \ge 0$.
  4. Take for the objective any vector $c \in {\mathbb R}^n$ such that $c^T v > 0$.
If you want a problem that is infeasible, take the dual of an unbounded problem.
awiebe
  • 1,185
Robert Israel
  • 470,583
    Any suggestions about what distribution to draw your random matrix from? – littleO Nov 25 '12 at 09:45
    It's really up to you. I'd use independent elements, each with some convenient continuous distribution (maybe uniform on an interval, maybe normal). – Robert Israel Nov 25 '12 at 19:34
