The determinant of an $n\times n$ matrix is a volume / volume factor. So far, I'm good in my understanding. You take a linear map, encode it as a matrix, compute the volume of the parallelepiped (or whatever the proper name is) spanned by the column vectors, and look at the factor by which this transformation scaled the unit $n$-dimensional volume from before the transformation to the new one. That scaling is the determinant. There are many ways to view the determinant, but this is the most interesting to me, because I can visualize it.
Now, what if I have a transformation from $\mathbb{R}^n$ to $\mathbb{R^m}$, encode it by an $m\times n$ matrix, and want the $n$-dimensional volume of the parallelepiped spanned by the column vectors of my matrix? This is a well-grounded question (think of a 2-d parallellogram embedded arbitrarily in 3-space: what is it's area?), but pretty much never addressed in linear algebra courses / books. Apparently (check e.g. the Wikipedia entry for determinants) I'm supposed to compute $\sqrt{\det(A^TA)}$ now.
This makes sense in the $m=n$ scenario (except that orientation changes might be lost due to the square root?), since $|\det(A)|=\sqrt{\det(A)^2}=\sqrt{\det(A^T)\det(A)}=\sqrt{\det(A^TA)}$, but I just can't visualize it in the case $n\neq m$. I see that the end result of the product $A^TA$ is an $n\times n$ matrix, so clearly the determinant is then an n-dimensional volume / volume factor, but I can't see why I get the correct volume. Any help?
