I went to a computer store to buy a LAN(Ethernet) cable and they asked me whether I want to connect two PCs or a PC to a router. I used to do both using same cable and it worked for me till I lost the cable. Is there really two different kind of LAN cables(other than performance types) for connecting two different PCs and a PC to a Router. If yes what is the difference between them?
Thomas
  • 497
In the past it was a requirement to use cross-over cable to connect PC to PC or hub to hub or switch to switch. The straight-through was used to connect PCs to networking equipment. Presently, most networking devices as well as PC NICs are implementing auto-MDIX feature that allows you to use straight-through cable to interconnect switches or two PCs. Moreover, if you get the cross-over cable that have only two pairs twisted most likely your 1Gb adapters would not negotiate 1Gb speed. So, the straight-through cable is the one you need.
Serge
  • 2,768
Yes, there is. What you are describing is called a crossover cable:
An Ethernet crossover cable is a type of Ethernet cable used to connect computing devices together directly. Normal straight through or patch cables were used to connect from a host network interface controller (a computer or similar device) to a network switch, hub or router. A cable with connections that "cross over" was used to connect two devices of the same type: two hosts or two switches to each other. Owing to the inclusion of Auto-MDIX capability, modern implementations of the Ethernet over twisted pair standards usually no longer require the use of crossover cables.
terdon
  • 54,564
For modern hardware you should never need a crossover cable. I have a lot of network equipment but zero crossover cables and everything works no matter how I connect it up (using regular patch cables).
