8
This is what I would like to achieve, but I'm failing (I'm a newbie in Linux).
I have a Fedora 16 box (64 bit) and would like to install multiple versions of oracle java (java 6 and java 7 for the moment). I'm trying to install java using the rpm software and I would like to install both of them under /opt.
I downloaded the required packages from the Oracle site:
jdk-6u30-linux-x64-rpm.bin
jdk-7u2-linux-x64.rpm
and extracted the rpm package from inside the .bin file running
./jdk-6u30-linux-x64-rpm.bin -x
obtaining the following situation:
jdk-6u30-linux-amd64.rpm
Then I looked inside jdk-6u30-linux-amd64.rpm with:
rpm -qpl ~/Downloads/jdk-7u2-linux-x64.rpm
and obtained that java 6 will install its files into:
/etc                   (some files)
/usr/java/jdk1.6.0\_30 (the majority of the files)
In a similar way java 7 will install into:
/etc
/usr/java/jdk1.7.0\_02
Because I want to install into /opt I tried to install using rpm relocation. Both packages seem to be rpm-relocatable, in fact:
rpm -qpi ~/Downloads/jdk-6u30-linux-amd64.rpm | grep -i reloc
gives as result
Relocations : /usr/java
and
rpm -qpi ~/Downloads/jdk-7u2-linux-x64.rpm | grep -i reloc
gives as result
Attempt 1 (install java 6 and then java 7)
sudo rpm -i --relocate /usr/java=/opt/java ~/Downloads/jdk-6u30-linux-amd64.rpm
this runs almost smoothly because rpm says
ln: failed to create symbolic link '/usr/java/jdk1.6.0\_30': No such file or directory`
rpm -q jdk
says
jdk-1.6.0\_30-fcs.x86\_64_ ... OK!
then
sudo rpm -i --relocate /usr/java=/opt/java ~/Downloads/jdk-7u2-linux-x64.rpm
fails tremendously saying:
file /etc/init.d/jexec from install of
jdk-2000:1.7.0\_02-fcs.x86\_64*     conflicts with file from package
jdk-2000:1.6.0\_30-fcs.x86\_64*
Attempt 2 (install java 7 and then java 6)
having yet installed java 6 I'll remove it first:
sudo rpm -e jdk*
sudo rpm -q jdk*
gives:
package jdk is not installed* <- OK, uninstalled!
then let's try installing java 7
sudo rpm -i --relocate /usr/java=/opt/java ~/Downloads/jdk-7u2-linux-x64.rpm*
gives the usual error:
ln: failed to create symbolic link '/usr/java/jdk1.7.0_02': No such file or directory`*
and now java 6
sudo rpm -i --relocate /usr/java=/opt/java ~/Downloads/jdk-6u30-linux-amd64.rpm*
fails saying two things:
package jdk-2000:1.7.0\_02-fcs.x86\_64 (which is newer than jdk-2000:1.6.0\_30-fcs.x86\_64) is already installed*
and
file /etc/init.d/jexec from install of jdk-2000:1.6.0\_30-fcs.x86\_64
conflicts with file from package jdk-2000:1.7.0\_02-fcs.x86\_64*
My questions are:
  1. symbolic link creation problem: is there a way to fix it? the installation process seems not to be aware that I tried to use the relocation mechanism, even if the package is relocatable (as far as I see)
  2. am I missing something in the installation process? Is it really possible to have both java 6 and java 7 on the same Linux machine? How? What am I doing wrong?
  3. Is there another way to achieve my goal?
PS: this is my first question here. I apologize in advance if something is wrong (from my English to the formatting and anything) PS2: I tried to add the tag sun-java7-jdk to this question but I haven't enough reputation to do it... should this tag be created?
N.N.
  • 1,379
5 Answers5
14
This is the more simple way, when you get this error:
package jdk.... (which is newer than jdk...) is already installed
Use the --force flag to install multiple versions.
So for example:
sudo rpm -ivh --force jdk-6u35-linux-amd64.rpm
Cojones
  • 241
I had similar problems getting Oracle java and OpenJDK to exist side by side on Fedora 16. I followed the guide on If not True then False and it worked perfectly.
bfj7
  • 46
jdk-7u2-linux-x64.rpm is newer than jdk-6u30-linux-amd64.rpm and the RPM package management tool is smart enough to overwrite it with the newer release.
The easiest way to install sun java 6 and sun java 7 side-by-side is to download the Java tarballs from Oracle and extract them into /opt
Ura
  • 1,051
I think Dejan is correct about installing the Java tarballs instead of the RPM. If you set up your JAVA_HOME and PATH correctly most uses will not need the additional setup that the RPM installation gives you (see this page for details of what jexec actually does).
One problem might be that some versions of the JDK do not make a tarball (*.tar.gz) available but instead just give you a *-rpm.bin and a *.bin. In this case the *.bin file is actually just a self extracting archive that results in the usual JAVA_HOME directory when you run it.
To install Java Runtime Environment on Fedora, Oracle Linux, Red Hat Enterprise Linux, etc.
# yum install java-1.7.0-openjdk
To intall package to developing programs using Java on Fedora, Oracle Linux, Red Hat Enterprise Linux, etc.
# yum install java-1.7.0-openjdk-devel
from http://namhuy.net/1195/how-to-install-oracle-java-jdk-7.html
Johny
  • 161
