11
Recently my Windows 7 x64 machine has been randomly crashing on me. Having recently installed a memory stick, I assumed that it was that, but after resolving that issue (See my question from before) and running multiple tests on the memory without any failure it appears that I have taken care of that issue.
However the PC still randomly crashes. After the crash whenever I look into the Event Viewer I see the same crtical error from Kernel-Power with Event ID of 41. Also with each crash there is a volmgr Error of Event ID 46 and a Wininit Warning with Event ID of 11. This crash happens randomly, and I just can't figure out what the cause is.
Here are the specific Errors and times that Windows reports:
  • Critical EVID 41 9/4/2010 9:42:07 PM
  • Critical EVID 41 9/3/2010 6:10:37 AM
  • Error EVID 46 9/4/2010 9:42:06 PM & 9:42:12 PM; 3:56:28 PM & 3:56:37 PM; 11:32:00 AM & 11:32:15 AM;
  • Error EVID 46 9/3/2010 3:29:06 PM & 3:29:12 PM; 6:10:37 AM & 6:10:46 AM
  • Error EVID 6008 9/4/2010 9:42:15 PM
  • Error EVID 6008 9/3/2010 6:10:58 AM
  • Warning EVID 11 9/4/2010 9:42:24 PM; 3:59:46 PM; 11:32:25 AM
  • Warning EVID 11 9/3/2010 3:29:24 PM; 6:10:58 AM
The PC crashes whenever I'm away. I have checked my power settings, and although I'm not sure what exactly I'm looking for I feel that everything is OK. Hibernate and sleep are off. Display is turned off after 15 min of inactivity, and the power setting is set to High Performance.
There have also been crashes while using the machine, for example:
  • Had a Word file open
  • Pandora was running (just switched to a commercial when it shut down)
  • I was scanning a document
  • Had Super User up :)
While these aren't very demanding applications the system shut down, it froze for a moment and then full system shutdown with a restart right after.
Looking at the error reporting brought up the exact same issues explained above, with an the additon of:
  • Application error (EID 1000) referring to the application of dlcxjswx.exe (However I think that may be my scanning software, it kept coming up with an error whenever I scanned)
After updating all of my drivers, I had to restart the PC. During the restart after updating the Realtek drivers, the system crashed once again. I am not sure if Realtek is the culprit but thought it might be important. Also, this prompted me to dig even deeper into the event viewer. Under the volmgr error EVID 46, the details tab shows "\Device\HarddiskVolume2" which happens to be my OS hard-drive. Does this mean that the drive is the issue (with it being a SSD/Hard Drive Hybrid)?
Heres my system info:
  • Case: HAF 932
  • Motherboard: EVGA P55 LE
  • Chipset: P55
  • Processor: Intel i5-750
  • Memory: 2x2 GB 1067; 2x1GB 1333 All modules are OCZ
  • Video Card: Nvidia GeForce 9500 GT
  • Power Supply: 750 Watts
  • Hard Drive: Seagate momentus xt 320 gb (OS); Seagate 750 GB; Seagate 1 TB; WD green 640 GB
Resolved
After opening the PC case and doing a "deep" inspection of everything on the PC, I saw something caught my eye. I looked further, and saw that both a USB and Firewall connection to the motherboard was not connected properly. It was actually connected one set of pins to the right of what it should be and upside down. Stupid mistake I know, but I found it out. I also updated drivers on everything and also have a replaced the PSU. So far, no more crashes.
So to everyone, double and triple check all your connections before you assume it's a software issue :P
James Mertz
  • 26,529
4 Answers4
As from reading comments, it appears that you are not 100% sure about BSOD/crashing, the first thing I would recommend you do is to disable automatic restarts on system failure (located in System Properties > Advanced Settings > Startup and Recovery).
Alternatively, or a better solution is to use Nirsoft Bluescreen View which should be able to show you all blue sreens that your machine has suffered from in the past - providing it was able to be written to disk.
As for an actual solution, I can't really give detailed advice any better than JBirch's answer as that is a good post on what the errors actually mean, but I have seen similar errors and if a client came to me with these errors, I would personally:
  1. Disconnect any cheap/unknown manufacturer PCI, PCI Express, USB or other addons. I have seen many crashes on standby caused via cheap Chinese webcams - but it can be any addon.
  2. Check for any BIOS updates.
  3. Check BIOS settings, especially power configuration. I have had issues with some P55 based motherboards and lowering the ACPI support level has fixed a few problems (granted it is only a work around, but it requires a BIOS update and without source code access, that is out of our control.)
  4. Possibly look at the BIOS and make sure you are not using a fancy RAID option - I have seen in the past random issues caused from using consumer motherboard RAID where the drivers simply are written poor. Unfortunately, this may require a reinstall but you may be able to get away without if you perform a Sysprep /generalise (If you want more information, read here)
  5. I would dump your hard drive. I have flat out refused to sell ANY hybrid hard drives recently. I sold about 30 when they were first released and within 4 months, I had to replace around 25 of them due to random crashes. A hard drive company I am partnered with send me samples to tempt me to sell, but I now perform a 72 hour burn in test on any new configuration, and hybrid drives never seem to pass or they show some sort of problem.
    This is my own research and I have found problems with any sort of SSD hybrid. it is my belief that the drivers are poorly written and whilst analysing memory dumps years ago with Intel Turbo Memory, I found the problem to be bad timings/cache. Items get written to the flash, and they are read from the drive before the flash has a chance to save - It has a low time out and the read is failed. Whilst opening documents or non critical files can be ok, if it is a critical Windows file, it can crash the system.
  6. Last normal idea would be overclocking - if you are doing this, disable it all - Core I5 is fast enough! This could be the cause.
  7. If all the above fails, my next thought is that you simply have a defective motherboard. It is rare, but it does happen, and when it does, you can have endless seemingly random problems. The only course of action is to RMA the board and receive a new one.
I hope this helps you and please let me know how you get on.
(Extra - I read somewhere above about a reference to Realtek drivers - For some, especially NIC, the ones that come with Windows Vista and Windows 7 are BAD, they cause BSOD, but only when utilisation reaches 70%+ - All the drivers on their site seem to be better and I haven't had a problem since)
William Hilsum
  • 117,648
A quick search of Kernel-Power Event ID 41 brings this up (which I imagine is the message you're given in Windows):
The last sleep transition was unsuccessful. This error could be caused if the system stopped responding failed or lost power during the sleep transition.
Does this crashing happen when you are not using the computer? Would you be able to have a look at your sleep and power settings for us? I figure this is more a symptom of the underlying problem, though.
The only information I'm getting on This EvID 46 on volmgr is
Crash dump initialization failed!
which probably means it's not what's causing the problems, but arises because of a cascading fault.
A search of Ev 11 on wininit is giving me
Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications
Which I could see as potentially causing the issue, either through maliciously crafted .dll files or something else. Do you have any timestamps on these errors, so we can see just what happens first?
JBirch
  • 476
So I was working on homework (of course) and the PC randomly shut down...
If I understand this correctly, your computer suddenly reboots while it is going to the sleep mode...
The other events listed are just side effects of the sudden reboot being detected at the next boot.
You should try to disconnect any external devices and work with a bare minimum hardware setup...
If it still occurs it's probably your power supply which either is broken or can't handle your hardware.
I had this issue where the computer would just shutdown for no reason when i reboot and go into the event viewer it says it ran a kernel-power 41 issue. I found that by updating my BIOS to the latest version this issue has stopped. So try updating your BIOS to the latest version.
