Is there anyway to read the battery capacity (in mah units) in Android SDK ?
Thanks
No, sorry. You can get a charge level remaining (EXTRA_LEVEL, a value from 0 to EXTRA_SCALE), but not a raw mAH value.
Yes it is possible, although there is no standard API to do so. Based on the Current Widget source code it reads a specific file for different devices.
Code below from: https://code.google.com/p/currentwidget/source/browse/trunk/CurrentWidgetLibrary/src/com/manor/currentwidget/library/CurrentReaderFactory.java
package com.manor.currentwidget.library;
import java.io.File;
import java.util.Locale;
import android.annotation.TargetApi;
import android.os.Build;
public class CurrentReaderFactory {
static final String BUILD_MODEL = Build.MODEL.toLowerCase(Locale.ENGLISH);
@TargetApi(4)
static public Long getValue() {
File f = null;
if (CurrentReaderFactory.BUILD_MODEL.contains("nexus 7")) {
f = new File("/sys/class/power_supply/battery/current_now");
if (f.exists()) {
return OneLineReader.getValue(f, false);
if (CurrentReaderFactory.BUILD_MODEL.contains("sl930")) {
f = new File("/sys/class/power_supply/da9052-bat/current_avg");
if (f.exists()) {
// Galaxy S4
if (CurrentReaderFactory.BUILD_MODEL.contains("sgh-i337")
|| CurrentReaderFactory.BUILD_MODEL.contains("gt-i9505")
|| CurrentReaderFactory.BUILD_MODEL.contains("gt-i9500")
|| CurrentReaderFactory.BUILD_MODEL.contains("sch-i545")
|| CurrentReaderFactory.BUILD_MODEL.contains("find 5")
|| CurrentReaderFactory.BUILD_MODEL.contains("sgh-m919")
|| CurrentReaderFactory.BUILD_MODEL.contains("sgh-i537")) {
if (f.exists()) {
if (CurrentReaderFactory.BUILD_MODEL.contains("cynus")) {
f = new File(
"/sys/devices/platform/mt6329-battery/FG_Battery_CurrentConsumption");
if (f.exists()) {
// Zopo Zp900, etc.
if (CurrentReaderFactory.BUILD_MODEL.contains("zp900")
|| CurrentReaderFactory.BUILD_MODEL.contains("jy-g3")
|| CurrentReaderFactory.BUILD_MODEL.contains("zp800")
|| CurrentReaderFactory.BUILD_MODEL.contains("zp800h")
|| CurrentReaderFactory.BUILD_MODEL.contains("zp810")
|| CurrentReaderFactory.BUILD_MODEL.contains("w100")
|| CurrentReaderFactory.BUILD_MODEL.contains("zte v987")) {
f = new File(
"/sys/class/power_supply/battery/BatteryAverageCurrent");
if (f.exists()) {
// Samsung Galaxy Tab 2
if (CurrentReaderFactory.BUILD_MODEL.contains("gt-p31")
|| CurrentReaderFactory.BUILD_MODEL.contains("gt-p51")) {
f = new File("/sys/class/power_supply/battery/current_avg");
if (f.exists()) {
// HTC One X
if (CurrentReaderFactory.BUILD_MODEL.contains("htc one x")) {
f = new File("/sys/class/power_supply/battery/batt_attr_text");
if (f.exists()) {
Long value = BattAttrTextReader.getValue(f, "I_MBAT", "I_MBAT");
if (value != null)
return value;
// wildfire S
if (CurrentReaderFactory.BUILD_MODEL.contains("wildfire s")) {
f = new File("/sys/class/power_supply/battery/smem_text");
if (f.exists()) {
Long value = BattAttrTextReader.getValue(f, "eval_current",
"batt_current");
if (value != null)
return value;
// trimuph with cm7, lg ls670, galaxy s3, galaxy note 2
if (CurrentReaderFactory.BUILD_MODEL.contains("triumph")
|| CurrentReaderFactory.BUILD_MODEL.contains("ls670")
|| CurrentReaderFactory.BUILD_MODEL.contains("gt-i9300")
|| CurrentReaderFactory.BUILD_MODEL.contains("gt-n7100")
|| CurrentReaderFactory.BUILD_MODEL.contains("sgh-i317")) {
if (f.exists()) {
// htc desire hd / desire z / inspire?
// htc evo view tablet
if (CurrentReaderFactory.BUILD_MODEL.contains("desire hd")
|| CurrentReaderFactory.BUILD_MODEL.contains("desire z")
|| CurrentReaderFactory.BUILD_MODEL.contains("inspire")
|| CurrentReaderFactory.BUILD_MODEL.contains("pg41200")) {
f = new File("/sys/class/power_supply/battery/batt_current");
if (f.exists()) {
// nexus one cyangoenmod
f = new File("/sys/devices/platform/ds2784-battery/getcurrent");
if (f.exists()) {
return OneLineReader.getValue(f, true);
// sony ericsson xperia x1
f = new File(
"/sys/devices/platform/i2c-adapter/i2c-0/0-0036/power_supply/ds2746-battery/current_now");
if (f.exists()) {
// xdandroid
/* if (Build.MODEL.equalsIgnoreCase("MSM")) { */
f = new File(
"/sys/devices/platform/i2c-adapter/i2c-0/0-0036/power_supply/battery/current_now");
if (f.exists()) {
// droid eris
if (f.exists()) {
Long value = SMemTextReader.getValue();
if (value != null)
return value;
// htc sensation / evo 3d
if (f.exists()) {
"batt_discharge_current", "batt_current");
if (value != null)
return value;
// some htc devices
if (f.exists())
// nexus one
if (f.exists())
// samsung galaxy vibrant
f = new File("/sys/class/power_supply/battery/batt_chg_current");
if (f.exists())
// sony ericsson x10
f = new File("/sys/class/power_supply/battery/charger_current");
if (f.exists())
// Nook Color
f = new File("/sys/class/power_supply/max17042-0/current_now");
if (f.exists())
// Xperia Arc
f = new File("/sys/class/power_supply/bq27520/current_now");
if (f.exists())
// Motorola Atrix
f = new File(
"/sys/devices/platform/cpcap_battery/power_supply/usb/current_now");
if (f.exists())
// Acer Iconia Tab A500
f = new File("/sys/EcControl/BatCurrent");
if (f.exists())
// charge current only, Samsung Note
f = new File("/sys/class/power_supply/battery/batt_current_now");
if (f.exists())
// galaxy note, galaxy s2
f = new File("/sys/class/power_supply/battery/batt_current_adc");
if (f.exists())
// intel
f = new File("/sys/class/power_supply/max170xx_battery/current_now");
if (f.exists())
// Sony Xperia U
f = new File("/sys/class/power_supply/ab8500_fg/current_now");
if (f.exists())
f = new File("/sys/class/power_supply/android-battery/current_now");
if (f.exists()) {
// Nexus 10, 4.4.
f = new File("/sys/class/power_supply/ds2784-fuelgauge/current_now");
if (f.exists()) {
f = new File("/sys/class/power_supply/Battery/current_now");
if (f.exists()) {
return null;
