I am currently experienced the following error when running my unit tests:
ReferenceError: Vue is not defined
> 10 | import hljsVuePlugin from '@highlightjs/vue-plugin';
Here is my component code:
<template>
<div>
<highlightjs autodetect :code="'hello world'" />
</div>
</template>
<script lang="ts">
import { defineComponent } from 'vue';
export default defineComponent({
components: {
highlightjs: hljsVuePlugin.component,
</script>
in my test file, I'm simply trying to mount this component:
const wrapper = mount(FooBlah, {
global: {
stubs: {
highlightjs: {
template: '<div />',
Here are my libraries versions:
"vue": "^3.2.33",
"@highlightjs/vue-plugin": "^2.1.2",
"highlight.js": "^11.6.0",
"@vue/cli-plugin-unit-jest": "~5.0.4",
"@vue/test-utils": "^2.0.2",
"@vue/vue3-jest": "^27.0.0",
Is there any way I could tell him to simply ignore the highlightjs the component in the jest.config ?
