I have a problem with the engine Godot, with the errors "body set shape disabled" and "body set shape as one-way collision".
In my project I have built four scenes:
The
platformscene formed by (StaticBody2Dwhich has as child objects(CollisionShape2D,Sprite,Position2D,Area2Dwhich in turn has a child object(Collisionshape2D))The
missilescene formed by (RigidBody2Dwhich has as child objects(CollisionShape2DandSprite));The
spaceshipscene formed by (Kinematicbody2Dwhich has as child objects(SpriteandCollisionShape2D));The
mainscene which has as root nodeNodeand as child objects: (platform and spaceship).
Moreover I have two scripts: one in the spaceship scene, on the Kinematicbody2D node; and then in the platform scene on the StaticBody2D node.
Basically when I start the game there is the platform at the top center and then there is the Area2D (with the CollisionShape2D to detect when a body enters the area and then there is also the Position2D that I set for a position where it should instantiate the missile at runtime).
When a body enters the Area2D the platform should instantiate a missile (which does nothing for the moment).
The problem arises when I direct the spaceship in the Area2D and the platform instantiates many times (more than 200-300 times per second) the missile and this is the moment when the game crashes. I get the errors that I wrote above and then I have to close it.
Spaceship Code:
extends KinematicBody2D
var target
var click
var dir
var collision
var speed = 200
func _input(event):
if event is InputEventMouseButton:
target = get_global_mouse_position()
click = true
func _physics_process(delta):
if click:
dir = position.direction_to(target)
collision = move_and_collide(dir * speed * delta)
if collision:
pass
Platform Code:
extends StaticBody2D
var trigger
var missileScene = preload("res://scenes/Missile.tscn")
var missile
func _on_DangerArea_body_entered(body):
if body is KinematicBody2D:
trigger = true
while(trigger):
missile = missileScene.instance()
$SpawnPosition.add_child(missile)
yield(get_tree().create_timer(3),"timeout")
func _on_DangerArea_body_exited(body):
trigger = false
