I am struggling with a probably minor problem while calling compiled ODEs to be solved
via the R package 'deSolve' and I seeking advice from more expert users.
Background
I have a couple of ODE systems to be solved with 'deSolve'. I have defined the ODEs in separate C++ functions (one for each model) I am calling through R in conjunction with 'Rcpp'. The initial values of the system change if the function takes input from another model (so basically to have a cascade).
This works quite nicely, however, for one model I have to set the initial parameters for t < 2. I've tried to do this in the C++ function, but it does not seem to work.
Running code example
#include <Rcpp.h>
using namespace Rcpp;
// [[Rcpp::export("set_ODE")]]
SEXP set_ODE(double t, NumericVector state, NumericVector parameters) {
List dn(3);
double tau2 = parameters["tau2"];
double Ae2_4 = parameters["Ae2_4"];
double d2 = parameters["d2"];
double N2 = parameters["N2"];
double n2 = state["n2"];
double m4 = state["m4"];
double ne = state["ne"];
// change starting conditions for t < 2
if(t < 2) {
n2 = (n2 * m4) / N2;
m4 = n2;
ne = 0;
dn[0] = n2*d2 - ne*Ae2_4 - ne/tau2;
dn[1] = ne/tau2 - n2*d2;
dn[2] = -ne*Ae2_4;
return(Rcpp::List::create(dn));
/*** R
state <- c(ne = 10, n2 = 0, m4 = 0)
parameters <- c(N2 = 5e17, tau2 = 1e-8, Ae2_4 = 5e3, d2 = 0)
results <- deSolve::lsoda(
y = state,
times = 1:10,
func = set_ODE,
parms = parameters
print(results)
The output reads (here only the first two rows):
time ne n2 m4
1 1 1.000000e+01 0.000000e+00 0.000000e+00
2 2 1.000000e+01 2.169236e-07 -1.084618e-11
Just in case: How to run this code example?
My example was tested using RStudio:
- Copy the code into a file with the ending *.cpp
- Click on the 'Source' button (or
<shift>+<cmd>+<s>)
It should work also without RStudio present, but the packages 'Rcpp' and 'deSolve' must be installed and to compile the code it needs Rtools on Windows, GNU compilers on Linux and Xcode on macOS.
Problem
From my understanding, ne should be 0 for time = 1 (or t < 2). Unfortunately, the solver does not seem to consider what I have provided in the C++ function, except for the ODEs. If I change state in R to another value, however, it works. Somehow the if-condition I have defined in C++ is ignored, but I don't understand why and how I can calculate the initial values in C++ instead of R.
