I have filenames like:
1234_56_78 A_FAIRLY_SHORT_TITLE_D.pdf
Luckily, the file naming is pretty consistent, but I can't absolutely guarantee that someone didn't use a space where they should have used an underscore.
With this in mind, I want to parse the string and extract the following details:
$project_no = '1234
$series_no = '56
$sheet_no = '78'
$revision = 'D'
$title = 'A Fairly Short Title'
Presently, I use the following to grab this info:
$filename = $_FILES['file']['name'][$i];
$filename = preg_replace('/\\.[^.\\s]{3,4}$/', '', $filename);
$parts = preg_split( "(_| )", $filename );
$project_no = $parts[0];
$series_no = $parts[1];
$sheet_no = $parts[2];
$revision = end($parts);
$title is simply everything that's left over after removing $parts[0] $parts[1], $parts[2], and end($parts), but how should I express that?
I thought I might be able to use
$title = implode(' ',\array_diff_key($parts, [0,1,2,end($parts)]));
But this doesn't remove the $revision bit at the end...
$title = FLOOR AS PROPOSED D
What am I missing, and am I unnecessarily over-complicating this?
