I used vue-cli to scaffold a new Typescript project and specified it should include vue-router.
This auto-generated a router/index.ts with a router configuration that looked like this:
const routes: Array<RouteConfig> = [
path: '/',
component: Home,
path: '/about',
component: () => { import(/* webpackChunkName: "about" */ '../views/About.vue') },
This file compiles fine as one would expect. However, when I try to call the route using <router-link> the About page does not render. I can confirm the route is being called, because if I add a console.log('x') into the import lambda above, I see the 'x' in the console but the About component constructor is never called and the About content is not rendered.
However, if I adjust the index.ts as follows (as per docs), then the route works correctly and displays the view:
const AboutRoute = () => import('../views/About.vue')
path: '/',
component: Home,
path: '/about',
component: AboutRoute,
Can anyone explain why the second version works, but not the first as they seem equivalent to me.
Thanks Ian
