I have set up the basics of Multipeer Connectivity successfully and my two devices recognize and connect to each other as peers. However, I am having trouble streaming and playing audio using AVAudioPlayerNode. I have a StartRecording() function called when a button is toggled, and it should open and close the OutputStream.
My general understanding is that you need to create an AVAudioEngine, attach an AVAudioPlayerNode, connect the AVAudioPlayerNode to the main mixer or output node (?). Then, from the sending device, start an outputStream, and installTap() on the Audio Engine's inputNode, which will continuously send the bytes converted from AVAudioPCMBuffer.
In the Multipeer functions, once stream data is received, I set the ViewController's inputStream which I think is handled using the StreamDelegate functions. The incoming bytes should then be handled (if there is space). The code seems to be functional, but .hasBytesAvailable is rarely called. I have microphone access enabled on both devices too.
Since it's hard to fit all the code in this post, I have created a public gist with relevant files. Here are the relevant parts from 3 main classes : ViewController.swift, MultipeerHandler.swift, StreamHelper.swift:
In ViewController.swift:
override func viewDidLoad() {
super.viewDidLoad()
configureAudioSession()
audioEngine = AVAudioEngine()
inputNode = audioEngine.inputNode
audioFormat = AVAudioFormat(commonFormat: .pcmFormatFloat32, sampleRate: 8000, channels: 1, interleaved: false)
multipeerSetup()
viewSetup()
private func configureAudioSession() {
do {
try audioSession.setCategory(.playAndRecord, options: .defaultToSpeaker)
try audioSession.setMode(.voiceChat)
try audioSession.setActive(true)
audioSession.requestRecordPermission() { [unowned self] (allowed: Bool) -> Void in
DispatchQueue.main.async {
if allowed {
print("allowed")
} catch { }
@objc func startRecording() throws {
// start streaming
if !(self.isRecording) {
audioEngine.stop()
let inputFormat = inputNode.inputFormat(forBus: 0)
audioEngine.attach(audioPlayer)
audioEngine.connect(audioPlayer, to: mainMixer, format: audioFormat)
// audioEngine.connect(audioPlayer, to: audioPlayer.outputNode, format: inputFormat)
do {
if multipeerHandler.session.connectedPeers.count > 0 {
if outputStream != nil {
outputStream = nil
outputStream = try multipeerHandler.session.startStream(withName: "voice", toPeer: multipeerHandler.session.connectedPeers[0])
outputStream.schedule(in: RunLoop.main, forMode: .default)
outputStream.delegate = self
outputStream.open()
inputNode.installTap(onBus: 0, bufferSize: AVAudioFrameCount(inputFormat.sampleRate/10), format: inputFormat) { (buffer: AVAudioPCMBuffer, when: AVAudioTime) in
let convertedFrameCount = AVAudioFrameCount((Double(buffer.frameLength) / inputFormat.sampleRate) * inputFormat.sampleRate)
guard let pcmBuffer = AVAudioPCMBuffer(pcmFormat: inputFormat, frameCapacity: convertedFrameCount) else {
print("cannot make pcm buffer")
return
print("\(#line)")
let bytes = StreamHelper.copyAudioBufferBytes(pcmBuffer)
if(self.outputStream.hasSpaceAvailable){
self.outputStream.write(bytes, maxLength: bytes.count)
print("\(#line)")
audioEngine.prepare()
try audioEngine.start()
} else {
print("no peers to connect to")
} catch let error {
print(error.localizedDescription)
self.isRecording = true
} else {
// stop streaming
inputNode.removeTap(onBus: 0)
self.isRecording = false
In MultipeerHelper.swift:
func session(_ session: MCSession, didReceive stream: InputStream, withName streamName: String, fromPeer peerID: MCPeerID) {
print("didReceiveStream")
if streamName == "voice" {
print(#line)
viewController.inputStream = stream
viewController.inputStream.delegate = viewController
viewController.inputStream.schedule(in: RunLoop.main, forMode: .default)
viewController.inputStream.open()
Also, it is important to note that I have found a lot of similar posts but they're somewhat old. Here are some of the sources I used to understand what's going on:
- https://github.com/nullforlife/Multipeer-Voice-Chat/blob/master/Multipeer%20Voice%20Chat/ViewController.swift
- Playing an audio file repeatedly with AVAudioEngine
- Trouble hooking up AVAudioUnitEffect with AVAudioEngine
- AVAudioPlayerNode doesn't play sound
- AVAudioEngine inputNode's format changes when playing an AVAudioPlayerNode
Once again, I have posted a public gist for this inquiry. Any help would be greatly appreciated.
