Story:
The legacy project is moving from VBA to VB.NET. One of the key functions is the connection to Excel. VBA function works always on any machine x32/x64, Windows 7/8/10, with just Excel installed.
The same function on VB.NET throws an error for users who don't have MS-Access installed.
System.Runtime.InteropServices.COMException: Provider cannot be found. It may not be properly installed.
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn)
at ConsoleApp3.Module1.Main() in ...source\repos\ConsoleApp3\ConsoleApp3\Module1.vb:line 11
Problem:
Users don't have Admin rights so any solution that requires installation of any software is not applicable.
Functions:
VBA perfectly works everywhere:
Sub workingVBAFunction()
Dim conn As Object
Dim connStr As String
Dim path As String
path = ThisWorkbook.FullName
connStr = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & path & ";Extended Properties=""Excel 12.0 Xml;HDR=YES"";"
Set conn = CreateObject("ADODB.Connection")
Call conn.Open(connStr)
conn.Close
Set conn = Nothing
End Sub
VB.NET works only on machines with MS-Access installed:
Sub failingDotNETFunction()
Dim conn As Object = CreateObject("ADODB.Connection")
Dim path As String
path = Environ("userprofile") & "\desktop\Book1.xlsm"
connStr = $"Provider=Microsoft.ACE.OLEDB.12.0;Data Source={path};Extended Properties=""Excel 12.0 Xml;HDR=YES;"";"
conn.Open(connStr)
conn.Close
End Sub
Question:
How to create a connection with VB.NET without MS-Access Engine on the Local machine? It should be possible because VBA somehow does it. How to replicate the behavior of VBA to VB.NET?
Already tried:
None of this works on machines without Access
- This Answer
- Changing the provider in the connection string:
- "Provider=Microsoft.JET.OLEDB.4.0;Data Source=" & path & ";Extended Properties='Excel 8.0 Xml'"
- "Driver={Microsoft Excel Driver (*.xls, *.xlsx, *.xlsm, *.xlsb)};DSN=Excel Files; DBQ=" & path & ";"
- "Excel File=" & path & ";"
- Build Application for Any CPU/x64/x86
