I'm quite confused on how 'Size and 'Component_Size work when reading input from a file and trying to use Unchecked_Conversion. I know that to sucsessfully use Unchecked_Conversion both the Source and the Target need to be the same size. I'm reading in input from a file like 000100000101001 and want to use Unchecked Conversion to put that into an array of Bits. However, the conversion always seems to fail because of them not being the same size or being too small.
with Ada.Unchecked_Conversion;
with Ada.Text_IO; use Ada.Text_IO;
with Ada.Integer_Text_IO; use Ada.Integer_Text_IO;
procedure main is
type Bit is mod 2 with size => 1;
type Bit_Array is array(Positive range <>) of Bit with pack;
subtype Bit15 is Bit_Array(1 .. 15); //subtypes because can't use conversion on unconstrainted type
subtype Bit11 is Bit_Array(1 .. 11);
function StringA_to_Bit15 is
new Ada.Unchecked_Conversion(source => String, target => Bit15);
begin
while not end_of_file loop
declare
s: String := get_line; //holding first line of input
len: constant Natural := (if s'length-3 = 15
then 15
else 11);
i: Integer;
ba: Bit_Array(1 .. len); //constrain a Bit_Array based on length of input
begin
ba := String_to_Bit15(s);
new_line;
end;
end loop;
Here are my types, Bit which can only be 0 or 1 with size to 1 bit. Bit_Array is just an array of Bit's which is unconstrained because my input can either be 15-Bits long or 11-Bits long. My thought was to just read in the first line into a String and convert it into a Bit_Array. This doesn't work because String and every other primitive type aren't Size => 1. So Naturally I would want to create a new type to handle this which I tried in the form of, creating my own String type and setting the size => 1 but Character requires 8-Bits. What data type would I need to create to read in a line of data and convert it such that it fits into a Bit_Array? I might be approaching this wrong but its very confusing for me. Any help or tips is appreciated!
