Currently using meteor flow-db-admin as admin template https://github.com/sachinbhutani/flow-db-admin
But the autoform doesn't seem to work with the simpl-schema as the labels don't show and the validation doesn't work
package.json
"name": "tours",
"private": true,
"scripts": {
"start": "meteor run",
"test": "meteor test --once --driver-package meteortesting:mocha",
"test-app": "TEST_WATCH=1 meteor test --full-app --driver-package meteortesting:mocha",
"visualize": "meteor --production --extra-packages bundle-visualizer"
"dependencies": {
"@babel/runtime": "^7.1.5",
"bcrypt": "^3.0.0",
"classnames": "^2.2.6",
"meteor-node-stubs": "^0.4.1",
"react": "^16.4.2",
"react-addons-pure-render-mixin": "^15.6.2",
"react-dom": "^16.4.2",
"react-mounter": "^1.2.0",
"simpl-schema": "^1.5.3"
"meteor": {
"mainModule": {
"client": "client/main.js",
"server": "server/main.js"
"testModule": "tests/main.js"
"devDependencies": {
"chai": "^4.1.2"
.meteor/packages
# Meteor packages used by this project, one per line.
# Check this file (and the other files in this directory) into your repository.
# 'meteor add' and 'meteor remove' will edit this file for you,
# but you can also edit it by hand.
meteor-base@1.4.0 # Packages every Meteor app needs to have
mobile-experience@1.0.5 # Packages for a great mobile UX
mongo@1.6.0 # The database Meteor supports right now
reactive-var@1.0.11 # Reactive variable for tracker
tracker@1.2.0 # Meteor's client-side reactive programming library
standard-minifier-css@1.5.0 # CSS minifier run for production mode
standard-minifier-js@2.4.0 # JS minifier run for production mode
es5-shim@4.8.0 # ECMAScript 5 compatibility for older browsers
ecmascript@0.12.0 # Enable ECMAScript2015+ syntax in app code
shell-server@0.4.0 # Server-side component of the `meteor shell` command
react-meteor-data
accounts-ui@1.3.1
accounts-password@1.5.1
meteortesting:mocha
twbs:bootstrap
static-html
jquery
kadira:flow-router
kadira:blaze-layout
dburles:collection-helpers
accounts-base@1.4.3
alanning:roles
fortawesome:fontawesome
meteortoys:allthings
check@1.3.1
aldeed:collection2-core
sach:flow-db-admin
aldeed:simple-schema
server/main.js
import { Meteor } from 'meteor/meteor';
// import '../imports/startup/accounts-config.js';
import '../imports/routes.js';
import '../imports/schemas.js';
// import '../imports/startup/admin-config.js';
Meteor.startup(() => {
AdminConfig = {
collections: {
Posts: {}
client/main.js
import React from 'react';
import { render } from 'react-dom';
AdminConfig = {
collections: {
Posts: {}
imports/schemas.js
// import { FlowRouter } from 'meteor/kadira:flow-router'
import { mount } from 'react-mounter';
import SimpleSchema from 'simpl-schema';
SimpleSchema.extendOptions(['autoform']);
Schemas = {};
Posts = new Meteor.Collection('posts');
Users = Meteor.users;
Schemas.Posts = new SimpleSchema({
title: {
label: 'Title',
type: String,
max: 60
content: {
label: 'Content',
type: String,
autoform: {
rows: 5
createdAt: {
type: Date,
label: 'Date',
autoValue: function () {
if (this.isInsert) {
return new Date();
owner: {
label: 'Author',
type: String,
regEx: SimpleSchema.RegEx.Id,
return Meteor.userId();
autoform: {
options: function () {
return _.map(Meteor.users.find().fetch(), function (user) {
return {
label: user.emails[0].address,
value: user._id
Posts.attachSchema(Schemas.Posts);
Then after launching, it shows the below; the validation doesn't work and the labels are not displayed also.
Please help
