I am trying to speed up inserts into a schema. I have seen some questions already about this however they do not deal with my issue, these are the most relevant:
The tables within my schema all include auto generated keys Serial, so I am using RETURNING id at the end of the inserts. The reason I am not using copy is that I need to check for constraints. Specifically some fields have unique indices, therefore I am checking if a specific row already exists so I can select its id (For the sake of mapping on the auto generated keys)
I do this:
sql = "INSERT INTO %s.%s(%s) VALUES (%s) ON CONFLICT DO NOTHING RETURNING %s;"
sql = sql % (schema_name,table_name,','.join(head[1:]),'%s',head[0])
where head contains the name of the fields in the table. Then I do this:
try:
# get the auto generated id back
return_id = pdb.cur.fetchone()[0]
except TypeError:
sql_exist_id = "SELECT %s FROM %s.%s WHERE %s = '%s'" % (head[0],schema_name,table_name,unique_field,row[1])
My question is: Is there a way to do a batch insert (like this psycopg2: insert multiple rows with one query) all while checking for constraints and returning keys ?
