https://github.com/garris/BackstopJS In example uses engine:'chrome', but in readme engine: 'chromy' Is that any difference in speed or result of test?
There is no difference other than using slightly different wording for the engine setting. You're still using Chromy with both methods and thus your tests will execute in exactly the same way.
Older versions of backstopjs used Chromy by default. The only available alternatives to Chromy were to use slimerjs or casperjs. See this from the older version of the backstopjs documentation:
Chrome-Headless (The latest webkit library)
This will also enable the very cool chromy.js (https://github.com/OnetapInc/chromy) library. (When creating onBefore and onReady scripts please make sure you are referring to the Chromy script documentation. Casper features will not work with this setting.)
"engine": "chrome"
So when you set your engine setting to chrome in the older versions, it would default-use Chromy as its engine.
However backstopjs has since been updated and now supports puppeteer as well as chromy and, since this change, you are required to set your engine as follows:
"engine": "puppeteer"
or
"engine": "chromy"
I would suggest that the reason for the difference in the examples is simply because the example in question is using an older version of backstopjs where you only needed to set chrome in order to use Chromy as the default engine.
- 3,280
- 2
- 19
- 30
"Chromy is no longer supported in version 5+. Please use version 4.x.x for chromy support." – Jake Dec 21 '20 at 06:03
