I have c/c++ code with embedded SQL for Oracle through Pro*C. Is there any mechanism to get the difference of values of array values and DB column values? For example, say, I have an array like this:
int nums[] = {10,20,35,45};
vector<int> vnums (nums, nums + sizeof(nums) / sizeof(int) );
Now, I have a DB table tbl1 with col1 containing values:
20
40
60
I would like to get the unmatched array values that are not present in tbl1.
So, result should be:
10
35
45
I know one way. I may run the following SQL query:
select col1 from tab1
And store the results in an vector say, vec2.
Now, I see the difference of these two vectors vnums and vec2.
Can you suggest a better way?
