I've got a script inside a body tag. Problem is some code is being loaded before it is finished even though it is in a document ready block. Shouldn't the code in the ready block wait for code in the script tag to finish? Or does it only hold off until the script tag is rendered but not executed?
<html>
<head>
<script data-main="script.js" src="/assets/js/require.js"></script>
</head>
<body>
<script type="text/javascript">
var foo = ${fromServer};
</script>
</body>
</html>
script.js: And I expect this to wait for until script is complete...
$(function() {
// access script var from here, not set yet hmmmm
I'd love to know what is going on here...
Update:
Okay now, here is the variable from the page
require.config({
baseUrl: '/assets/js/app',
shim: {
d3: {
exports: 'd3'
underscore: {
exports: '_',
backbone: {
deps: ['underscore', 'jquery'],
exports: 'Backbone'
uidate: {
deps: ['jquery']
paths: {
d3: '../lib/d3.v3',
jquery: '../lib/jquery-2.0.3.min',
underscore: '../lib/underscore',
backbone: '../lib/backbone'
require([...], function(...) {
//console.log here and foo is set and good to go
var myCollection = new MyCollection(foo);
inside MyCollection:
// define(.... {
// var coll = Backbone.Collection.extend({
initialize: function() {
console.log(this);
Looking at the console I see:
{length: 0, models: Array[0], _byId: Object, constructor: function, model: function…}
When I expand the object in Chrome console there are actually models in there.... strange. If I do a setTimeout inside init and console.log(this) again the models are set. Where is this delay of initialising the models coming from?
I've also tried just loading an array like:
var someColl = new MyCollection([ { ... }, { ... } ]);
Same problem here too.
Update: I've tried to narrow down the scope of the problem, console.log prints an empty array here
var testing = [{x:1,d:2},{x:3,d:8},{x:3,d:98}];
var myCollection = Backbone.Collection.extend({
console.log(JSON.stringify(this));
var x = new myCollection(testing);
