What is the role of user agent switcher?
https://addons.mozilla.org/en-US/firefox/addon/59
Is the user agent different than the rendering engine?
If a browser uses the same rendering engine then do we need to check on every browser?
But even if you switch the user agent of lets say firefox to safari, it will still use the gecko rendering engine to render it's page.
So to check how a page renders in different browsers you really need to render the page in those different browsers.
User agent is the string the browser sends along in the HTTP headers to identify itself. This is how various sites distinguish between IE, FireFox/Mozilla, Safari/Webkit, and the like.
A user agent informs the site of the rendering engine involved, but is not itself the rendering engine.
Role of User Agent Switcher is mainly to switch one browser to another browser which is called User agent. This is how all the server side language identifies through which software their application is accessed and which device etc.
When a software agent operates in a network protocol, it often identifies itself, its application type, operating system, software vendor, or software revision.
Have a look at Browser Arch and list of engines for each browser.
Browser Architecture
Browser Engines List
Click here to Refer to my Article to understand what is there behind Browser. https://medium.com/@ramsunvtech/behind-browser-basics-part-1-b733e9f3c0e6
Some websites render content differently according to the User Agent that is being sent. For example, if the User Agent is IE 6, the language used to render the webpage (e.g. PHP) could be used to add a class "ie6" to an element, and then CSS is used to control what gets displayed or not. Or, a separate js file can be added depending on the user agent.
Some years ago, Opera recommended that you set the User Agent as IE 6, because websites will consistently not render if the User Agent was not any of IE or Mozilla. But, I think this is no longer the case.
A user/client can change the user agent for a browser. Where as the way the browser renders the markup code does not change.
