I'm really getting so frustrated - cannot resolve following issue:
  • My wallet is showing the wrong balance
  • I cannot transfer any money ("Daemon is busy")
Seems like I am on the wrong chain, right?
So I tried following this guideline:
I forgot to upgrade (from CLI or GUI v0.11 to CLI or GUI v0.12) and, as a result, accidentally synced to the wrong (alternative) chain
I updated from 12.2 to 12.3 and now I've been waiting for days and theres nothing happening. I am on Macosx High Sierra using the GUI version.
This is what my log says:
[31.07.18 09:01] Height: 1622140/1622140 (100.0%) on mainnet, not mining, net hash 458.90 MH/s, v7, up to date, 0(out)+0(in) connections, uptime 0d 8h 1m 44s [31.07.18 09:02] Height: 1622140/1622140 (100.0%) on mainnet, not mining, net hash 458.90 MH/s, v7, up to date, 0(out)+0(in) connections, uptime 0d 8h 2m 44s
The latest transaction to this wallet happened in block no "1615882" with now "No of confirmations: 12630" - these funds are not showing in my wallet and I cannot transfer the existing funds...
I do not want to delete the whole blockchain and start over from scratch...
Do you have any tips? I really do need the money :( - Thank u
j doe
You should try to rescan your wallet for spent output with rescan_spent from the cli. It should remove your spent transaction done on the wrong blockchain.
Otherwise you could try to pop the blocks to restart syncing before the transaction:
./monero-blockchain-import --pop-blocks 6500
This will remove the 6500 blocks and when you will restart monerod it will sync again.
Edit: try first option. If it does not help, pop the blocks and scan again.
el00ruobuob
  • 845
