I need help to find an analytical solution to:
$$p''(x)-k_1xp'(x)-k_2p(x)=0 \text{ where } k_1,k_2\in\mathbb R^+$$
with boundary conditions $p'(0)=0, p(r)=p(-r)=k_3$ where $r,k_3\in\mathbb R^+$. Mathematica gives as solution the ratio of two Hypergeometric $_1F_1$ (Kummer) functions but I'd like to know if Mathematica is right and a possible solution procedure.
Thanks a lot.
matt
  • 1,449
Goteb
  • 11
Let $p(x)=\int_Ce^{xs}K(s)~ds$ ,
Then $(\int_Ce^{xs}K(s)~ds)''-k_1x(\int_Ce^{xs}K(s)~ds)'-k_2\int_Ce^{xs}K(s)~ds=0$
$\int_Cs^2e^{xs}K(s)~ds-k_1x\int_Cse^{xs}K(s)~ds-k_2\int_Ce^{xs}K(s)~ds=0$
$\int_C(s^2-k_2)e^{xs}K(s)~ds-\int_Ck_1se^{xs}K(s)~d(xs)=0$
$\int_C(s^2-k_2)e^{xs}K(s)~ds-\int_Ck_1sK(s)~d(e^{xs})=0$
$\int_C(s^2-k_2)e^{xs}K(s)~ds-[k_1se^{xs}K(s)]_C+\int_Ce^{xs}~d(k_1sK(s))=0$
$\int_C(s^2-k_2)e^{xs}K(s)~ds-[k_1se^{xs}K(s)]_C+\int_Ce^{xs}(k_1sK'(s)+k_1K(s))~ds=0$
$-~[k_1se^{xs}K(s)]_C+\int_C(k_1sK'(s)+(s^2+k_1-k_2)K(s))e^{xs}~ds=0$
$\therefore k_1sK'(s)+(s^2+k_1-k_2)K(s)=0$
$k_1sK'(s)=(k_2-k_1-s^2)K(s)$
$\dfrac{K'(s)}{K(s)}=\left(\dfrac{k_2}{k_1}-1\right)\dfrac{1}{s}-\dfrac{s}{k_1}$
$\int\dfrac{K'(s)}{K(s)}ds=\int\left(\left(\dfrac{k_2}{k_1}-1\right)\dfrac{1}{s}-\dfrac{s}{k_1}\right)ds$
$\ln K(s)=\left(\dfrac{k_2}{k_1}-1\right)\ln s-\dfrac{s^2}{2k_1}+c_1$
$K(s)=cs^{\frac{k_2}{k_1}-1}e^{-\frac{s^2}{2k_1}}$
$\therefore p(x)=\int_Ccs^{\frac{k_2}{k_1}-1}e^{-\frac{s^2}{2k_1}+xs}~ds$
But since the above procedure in fact suitable for any complex number $s$ ,
$\therefore p_n(x)=\int_{a_n}^{b_n}c_n(m_nt)^{\frac{k_2}{k_1}-1}e^{-\frac{(m_nt)^2}{2k_1}+xm_nt}~d(m_nt)={m_n}^{\frac{k_2}{k_1}}c_n\int_{a_n}^{b_n}t^{\frac{k_2}{k_1}-1}e^{-\frac{{m_n}^2t^2}{2k_1}+m_nxt}~dt$
For some $x$-independent real number choices of $a_n$ and $b_n$ and $x$-independent complex number choices of $m_n$ such that:
$\lim\limits_{t\to a_n}t^{\frac{k_2}{k_1}}e^{-\frac{{m_n}^2t^2}{2k_1}+m_nxt}=\lim\limits_{t\to b_n}t^{\frac{k_2}{k_1}}e^{-\frac{{m_n}^2t^2}{2k_1}+m_nxt}$
$\int_{a_n}^{b_n}t^{\frac{k_2}{k_1}-1}e^{-\frac{{m_n}^2t^2}{2k_1}+m_nxt}~dt$ converges
For $n=1$, the best choice is $a_1=0$ , $b_1=\infty$ , $m_1=\pm1$
$\therefore p_1(x)=C_1\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh xt~dt$ or $C_1\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\sinh xt~dt$
Hence $p(x)=C_1\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\sinh xt~dt+C_2\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh xt~dt$
$p'(x)=C_1\int_0^\infty t^{\frac{k_2}{k_1}}e^{-\frac{t^2}{2k_1}}\cosh xt~dt+C_2\int_0^\infty t^{\frac{k_2}{k_1}}e^{-\frac{t^2}{2k_1}}\sinh xt~dt$
$p'(0)=0$ :
$C_1\int_0^\infty t^{\frac{k_2}{k_1}}e^{-\frac{t^2}{2k_1}}~dt=0$
$C_1=0$
$\therefore p(x)=C_2\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh xt~dt$
$p(\pm r)=k_3$ :
$C_2\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh rt~dt=k_3$
$C_2=\dfrac{k_3}{\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh rt~dt}$
$\therefore p(x)=\dfrac{k_3\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh xt~dt}{\int_0^\infty t^{\frac{k_2}{k_1}-1}e^{-\frac{t^2}{2k_1}}\cosh rt~dt}$
doraemonpaul
  • 16,488
