Let $G$ be a finite group and $H<G, K<G$.
I have shown that $\left[G:H\cap K\right]\leq\left[G:H\right]\left[G:K\right]$
But I do not know where to begin to prove the equality in case these indexes are coprime.
I'd appreciate it much if a hint could be given.
dankilman
  • 199
Two hints:
  1. $[G: H \cap K] = [G:H][H: H \cap K] = [G:K][K: H \cap K]$.
  2. if $a \mid bc$ and $\gcd(a,b) = 1$, then $a \vert c$.
user26857
  • 53,190
Zarrax
  • 46,591
I would first show that $[G:H \cap K] = [G:H] \cdot [H : H\cap K]$.
user5262
  • 1,923
First of all, you can consider a homomorphism between $H$$\times$$K$ to $G$ taking elements of the form $(h,k)$ to $hk$. Then consider the kernel of this homomorphism and try to apply first isomorphism theorem. Of course, for a full writing, firstly you should verify that the map we define is actually a well-defined group homomorphism.
By this attempt, you will get an inequality not an equality that @user5262 wrote. But you will be one step further. Then use coprimeness to reach the equality.
sez
  • 126
