Question:
$$3\dot{x} + \dot{y} + 5x - y = 2e^{-t}+4e^{-3t}$$ $$\dot{x} + 4\dot{y} - 2x + 7y = -3e^{-t}+5e^{-3t}$$
Subject to:
$$x(0)=y(0)=0$$ Attempt at a solution:
I have gotten to:
$$\left(\begin{array}{cc}1&-1&3&-3\\ 1&1&1&1\end{array}\right)\left(\begin{array}{cc}\dot{x}\\ \dot{y}\\ x \\ y \end{array}\right) = 2 \left( \begin{array}{cc}e^{-t}\\ e^{-3t}\end{array}\right) $$
But I am not sure what to do next.
    Try to write the system with only $\dot x$ and $\dot y$ in the right hand side so you can invert the matrix. – Sergio Parreiras May 20 '14 at 13:54
    Write it in the form $\left( \begin{matrix} {\dot{x}} \ {\dot{y}} \ \end{matrix} \right)=A\left( \begin{matrix} x \ y \ \end{matrix} \right)+B\left( \begin{matrix} {{e}^{-t}} \ {{e}^{-3t}} \ \end{matrix} \right)$ – Paul May 20 '14 at 14:30
Note that your system can be rewritten in a more convenient form as follows:
$$A \,Y'(t) = B\, Y(t) + C(t),$$ where $Y(t) = (x(t),y(t))$, $C$ is the vector of independent terms and $A$ and $B$ are given by:
$$ A = \left( \begin{array}{cc} 3 & 1 \\ 1 & 4 \end{array} \right), \quad B = \left( \begin{array}{cc} -5 & 1 \\ 2 & -7 \end{array} \right). $$ Since $\det{A} \neq 0$ you may multiply both sides by $A^{-1}$ to get:
$$Y'(t) = M \, Y(t) + D(t), $$ with $M = A^{-1} B$ and $D = A^{-1} C$. I'm sure you can take it from here.
Spoiler:
If I remember well, the solution is then given by: $$ Y(t) = Y_0 \Phi(t) + \Phi(t) \int^t_0 \Phi^{-1}(s) D(s) \, \mathrm{d}s, $$ where $\Phi(t) = \exp{At}$ is the fundamental matrix of the system and $Y_0$ is the vector of initial conditions.
Cheers!
Dmoreno
  • 7,647
One way to rewrite: $$ \left[\begin{array}{cc} 3 & 1 \\ 1 & 4\end{array}\right] \frac{d}{dt}\left[\begin{array}{c} x \\ y\end{array}\right]+ \left[\begin{array}{cc} 5 & -1 \\ -2 & 7\end{array}\right] \left[\begin{array}{c} x \\ y\end{array}\right]= \left[\begin{array}{cc} 2 & 4 \\ -3 & 5\end{array}\right] \left[\begin{array}{c} e^{-t} \\ e^{-3t}\end{array}\right]. $$ Multiplying by the inverse $$ \left[\begin{array}{cc} 3 & 1 \\ 1 & 4\end{array}\right]^{-1}= \frac{1}{11}\left[\begin{array}{cc} 4 & -1 \\ -1 & 3\end{array}\right]^{-1} $$ gives $$ \frac{d}{dt}\left[\begin{array}{c}x \\ y\end{array}\right]+ \left[\begin{array}{cc} 2 & -1 \\ -1 & 2\end{array}\right] \left[\begin{array}{c} x \\ y\end{array}\right]= \left[\begin{array}{cc} 1 & 1\\ -1 & 1\end{array}\right] \left[\begin{array}{c} e^{-t} \\ e^{-3t}\end{array}\right]. $$ The coefficient matrix $C$ on the left has characteristic polynomial $(\lambda-2)^{2}-1=(\lambda-3)(\lambda-1)$. So the coefficient matrix has diagonal representation: $$ C=\left[\begin{array}{cc} 2 & -1 \\ -1 & 2\end{array}\right] = U^{T}\left[\begin{array}{cc}3 & 0 \\ 0 & 1 \end{array}\right]U\;\;\; \mbox{ where } U = \frac{1}{\sqrt{2}}\left[\begin{array}{cc}1 & -1 \\ 1 & 1\end{array}\right]. $$ Therefore, $$ e^{tC} = U^{T}\left[\begin{array}{c}e^{3t} & 0\\0 & e^{t}\end{array}\right]U = \frac{1}{2}\left[\begin{array}{cc}1 & 1 \\ -1 & 1\end{array}\right] \left[\begin{array}{c}e^{3t} & 0\\0 & e^{t}\end{array}\right] \left[\begin{array}{cc}1 & -1 \\ 1 & 1\end{array}\right] $$ Multiplying both sides of the differential equation by the matrix $e^{tC}$ gives $$ \frac{d}{dt}\left(e^{tC}\left[\begin{array}{c}x \\ y\end{array}\right]\right) = e^{tC}\left[\begin{array}{cc} 1 & 1\\ -1 & 1\end{array}\right] \left[\begin{array}{c} e^{-t} \\ e^{-3t}\end{array}\right] $$ Integrating, $$ e^{tC}\left[\begin{array}{c}x \\ y\end{array}\right] -\left[\begin{array}{c}x(0) \\ y(0)\end{array}\right] = \int_{0}^{t} e^{sC}\left[\begin{array}{cc} 1 & 1\\ -1 & 1\end{array}\right] \left[\begin{array}{c} e^{-s} \\ e^{-3s}\end{array}\right]\,ds $$ Applying $x(0)=y(0)=0$ and the specific form of $e^{sC}$ yields the final answer $$ \begin{align} \left[\begin{array}{c} x \\ y\end{array}\right] & = e^{-tC}\int_{0}^{t} \left[\begin{array}{cc} 1 & 1\\ -1 & 1\end{array}\right] \left[\begin{array}{cc} e^{2s}\\e^{-2s}\end{array}\right]\,ds \\ %% & = \left[\begin{array}{cc} 1 & 1\\ -1 & 1\end{array}\right] %% \left[\begin{array}{cc} e^{-3t} & 0 \\ 0 & e^{-t}\end{array}\right] %% \int_{0}^{t}\left[\begin{array}{cc} e^{2s}\\e^{-2s}\end{array}\right]\,ds \\ %% & = \left[\begin{array}{cc}e^{-3t} & e^{-t} \\ -e^{-3t} & e^{-t}\end{array}\right] %% \frac{1}{2}\left[\begin{array}{c}e^{2t}-1 \\ 1-e^{-2t}\end{array}\right] \\ %% & = \frac{1}{2}\left[\begin{array}{cc}e^{-t}-e^{-3t}+e^{-t}-e^{-3t} \\ %% -e^{-t}+e^{-3t}+e^{-t}-e^{-3t}\end{array}\right] \\ & = \left[\begin{array}{c}e^{-t}-e^{-3t} \\ 0\end{array}\right]. \end{align} $$
Disintegrating By Parts
  • 91,908
  • 76
  • 168
