I understand that you have to write out all the disjoint cycles and then take the least common multiple which yields the highest order.
But my question is, do I have to write all elements of $S_5$, write them as disjoint cycles, and then find the largest least common multiple, or is there a shortcut?
$S_5$ has $5!$ elements and I would not like writing all of these permutations out...
I have read the other answers on here but I have not seen anything to help me with this question.
For example, here (https://math.stackexchange.com/a/231893/133156) the answer lists six disjoint cycles of $S_5$, how did he get there without writing them all out?
H5159
  • 999
You only need to write out all possible structures for disjoint cycles. They correspond to the (additive) partitions for $5$:
$5 = 5 $ corresponds to one $5$-cycle.
$5 = 4 + 1 $ corresponds to one $4$-cycle and one $1$-cycle, but $1$-cycles can be ignored.
$5= 3 + 2 $ corresponds to one $3$-cycle and one $2$-cycle.
etc...
lhf
  • 221,500
    So it would follow as such: $$5=5+0$$ $$5=4+1$$ $$5=3+2$$ $$5=3+1+1$$ $$5=2+2+1$$ $$5=2+1+1+1$$. So the largest order would be $$lcm(3,2)=6$$. – H5159 Apr 11 '14 at 02:41
  • How have I missed any? These are the only additions to yield 5 for disjoint cycles. I'm confused how I missed four. Also, the author of the answer in the link only lists these 6, not 10. – H5159 Apr 11 '14 at 02:48
  • I still do not understand, can you elaborate? The largest least common multiple is with the product of two disjoint cycles of length 2 and 3. I don't see why you are mentioning 4 as a least common multiple. – H5159 Apr 11 '14 at 02:57
  • @Frumpy, you're right, I misread. – lhf Apr 11 '14 at 02:58
  • I'm going to try $S_6$ now :) – H5159 Apr 11 '14 at 03:01
  • Is there a general formula for the possible structure of disjoint cycles of a given symmetric group? I found 10 for $S_6$. Is this correct? – H5159 Apr 11 '14 at 03:08
  • There is no formula. See https://oeis.org/A000793. And it's $6$ for $S_6$. – lhf Apr 11 '14 at 03:09
  • I know that the greatest is 6, but can you verify if the structure of a disjoint cycle has 10 forms? – H5159 Apr 11 '14 at 03:10
  • For the number of partitions, see http://oeis.org/A000041. – lhf Apr 11 '14 at 03:10
  • Does that sequence start at 0 or 1? If it starts at 0, I think I am leaving the identity out where we have 1+1+1+1+1+1. Is that why I have 6 for $n=6$ and 10 for $n=6$ (speaking of the possible structures of disjoint cycles) – H5159 Apr 11 '14 at 03:13
