Recently I came across this integral:
$$ \int_0^{\infty} \frac{1}{1+e^{\sqrt{x}}}\mathrm dx$$
I know that its solution is $\frac{\pi^2}{6}$, through numerical approaches but I'm not entirely sure how you would go about solving the integral analytically.
Initially I tried the trick of adding the exponential term and taking it away from the numerator as this works in the case where there is no square root in the exponent, however I don't believe this to be a fruitful approach. Thanks for any help/advice any of you can offer.
Quanto
  • 120,125
Slice
  • 93
Substitute $t=e^{-\sqrt x}$ $$ \int_0^{\infty} \frac{1}{1+e^{\sqrt{x}}}dx=-2\int_0^1 \frac{\ln t}{1+t}dt =-2(-\frac{\pi^2}{12})=\frac{\pi^2}6 $$ where $\int_0^1 \frac{\ln t}{1+t}dt\overset{ibp}=- \int_0^1 \frac{\ln (1+t)}{t}dt = -\frac{\pi^2}{12} $.
Quanto
  • 120,125
The integral equals $$\sum_{n=1}^\infty(-1)^{n-1}\int_0^\infty e^{-n\sqrt x}dx.$$ Substitute $y=n^2x$ which gives $$\sum_{n=1}^\infty \frac{(-1)^{n-1}}{n^2}\int_0^\infty 2ye^{-y}dy.$$ Now combine Alternating Reciprocal of Squares with $$\int_0^\infty ye^{-y}dy=\Gamma(2)=1.$$
Kenta S
  • 18,181
