I’m trying to follow this proof: proof
Specifically this part:
The parameters $t_1,t_2$ of possible common points of line $g: \vec x=\vec p+t\vec v$ (through $P$) and circle $c$ can be determined by inserting the parametric equation into the circle's equation: :$(\vec p+t\vec v)^2-r^2=0 \quad \rightarrow \quad t^2+2t\;\vec p\cdot\vec v +\vec p^2-r^2=0 \ .$
Can anyone explain this further? I don’t understand why the parametric equation of a line is being substituted into the equation for a circle.
I already asked a question to clarify the first part: question to clarify circle part
notaorb
  • 143
    "I don’t understand why the parametric equation of a line is being substituted into the equation for a circle." That's how you intersect two curves: You want a point that is in both curves, so it need so satisfy both equations. A typical way to solve a system of two equation is to solve for one variable in one of the equations (in this case you already have the equation of the line solved for $x$) and substitute the variable in the other equation. – jjagmath Sep 20 '24 at 19:28
    If you are banging your head on learning from Wikipedia (not surprising, it's not meant to teach), I'd suggest either listening to someone teach about it, or reading a textbook . Here is a video lecture on power of a point: https://www.youtube.com/watch?v=zMMOVxiXak8 – RobinSparrow Sep 20 '24 at 19:52
  • @jjagmath you have the answer – notaorb Sep 20 '24 at 23:41
The parametric equation of the line gives all the points by varying the parameter. You get a vector function $\vec x(t)$ of a scalar argument.
The circle is represented by an implicit equation, which is the locus of the vectors such that they cancel a function (namely the squared distance to the center minus the squared radius). You get a scalar function of a vector argument, $c(\vec x)$.
But combining the two, $c(\vec x(t))$, you get a scalar function of a scalar argument and you need to find the roots, which correspond to the intersection(s). From the value(s) of $t$ you get the point(s).
Four alternatives are possible: implicit or parametric line equation vs. implicit or parametric circle equation. Each form systems of $k$ equations in $k$ unknowns. The given method is simple as it corresponds to $k=1$.
$r$ is the constant scalar geometric mean of all segment vector lengths through P. Start by squaring algebraically and then take the dot product
$$(\vec p + t \vec v )\cdot (\vec p + t \vec v)=r^2 $$ $$=(\vec p \cdot \vec p ) + 2 t\vec p \vec v + (t\vec v \cdot t \vec v) =r^2 $$ $$=(\vec p \cdot \vec p ) + 2 t\vec p \vec v + (t\vec v \cdot t \vec v)=r^2 $$ $$=(\vec p ^2) + 2 t\vec p \vec v + (t^2 1)=r^2 $$
with the last being dot product of two unit vectors
Narasimham
  • 42,260
