Prove that if $|a|<1$ then $$\lim_{n\to\infty}{n\cdot a^n}=0$$ Lopital's rule won't help here, and this problem appears in a book before lopital has been taught.
I noticed that: $$\frac{a_{n+1}}{a_n}=a\frac{n+1}{n}\to a$$
So, can I conclude that it behaves like a geometric series for large n, so it converges to zero?
*Other solution methods are welcome.
NightRa
  • 1,572
    http://math.stackexchange.com/questions/197522/how-to-prove-that-lim-n-to-infty-n-xn-0-when-0x1 and http://math.stackexchange.com/questions/173061/sequence-limit-lim-limits-n-rightarrow-inftyn-xn – lab bhattacharjee Aug 26 '13 at 18:54
  • Yeah. Couldn't find it. Can you tell me how you search for this kind of stuff? – NightRa Aug 26 '13 at 18:58
  • @NightRa You can try to google using your search terms and "site:mathstackexchange.com". The google search sometimes gets you there faster. – rschwieb Aug 26 '13 at 19:54
You intuition is spot on. You have that $$\lim\limits_{n\to\infty}\frac{a_{n+1}}{a_n}=a<1$$
Now choose a number $\ell$ with $a<\ell<1$. By the definition of limit, there must exist $N>0$ such that whenever $n\geqslant N$ we have $$\frac{a_{n+1}}{a_n}<\ell $$
In particular when $k=1,2,3,\ldots$ $$a_{N+k}<\ell a_{N+k-1}$$
By repeated use of this we can write, for $k=1,2,\ldots,$ that $$a_{N+k}<\ell ^k a_N$$
Note $N$ is fixed, so as $k\to\infty$ we get that $$\lim\limits_{k\to\infty}a_{N+k}\leqslant a_N \lim_{k\to\infty} \ell^k=0$$
Since we know $a_n\geqslant 0$; we conclude $\lim\limits_{k\to\infty} a_k=0$.
This is indeed the very idea behind D'Alambert's criterion
Let $\langle a_n\rangle $ be a sequence of positive terms, and suppose that $$\lim_{k\to\infty}\frac{a_{k+1}}{a_k}=\ell <1$$ Then $\lim\limits_{k\to\infty} a_k=0$. What's more, $\displaystyle\sum_{k\geqslant 0}a_k$ exists.
In fact, if you know about $\limsup$ and $\liminf$; we can give a finer criterion.
If $$\ell =\limsup\limits_{n\to\infty}\frac{a_{n+1}}{a_n}<1$$ then the sequences is absolutely summable. If $$\ell'=\liminf\limits_{n\to\infty}\frac{a_{n+1}}{a_n}>1$$ then the sequence is not summable (the sum diverges).
Pedro
  • 125,149
  • 19
  • 236
  • 403
$$\lim_{n \to \infty} n.a^n= y$$ taking log on both sides $$\lim_{n \to \infty} log(n) + nlog(a)= log(y)$$ as $a<1$ ,$log(a) = -log(\frac{1}{a})$ and $\frac{1}{a}>1$ $$\to \lim_{n \to \infty}log(n) - nlog( \frac{1}{a} )= log(y)$$ as $ nk >log(n)$ $(k =log(\frac{1}{a})$ $$log(y) \to -\infty$$ or$$y \to 0$$
Suraj M S
  • 1,899
-3
Let $\frac{1}{b} = a$ where |b|>1 therefore the limit becomes $$\lim_{n\to\infty}{n\cdot \frac{1}{b^n}}=0$$ As n increases the absolute value of the denomenator increases and therefore the absolute value of the entire expression becomes smaller and therefore converges to zero.
Prankster
  • 567
    (-1 for not an explanation) Saying that the absolute value of the denominator increases is correct, but why does it increase much faster than the absolute value of the numerator? Just because the denominator grows doesn't mean that the limit is zero. –  Aug 26 '13 at 19:12
