How do you go about finding the integer solutions for something like that? : $$a^bx + c^dy$$ where $a,b,c,d$ are positive integers and $a$ is odd and $c$ is even
Using bezouts idenity we know that there exists solutions for: $$a^bx + c^dy = gcd(a^b, c^d)$$ and since $a^b, c^d$ share no common factors $$a^bx + c^dy =1$$
The problem is, how do you apply Extended Euclidean algorithm on $a^b, c^d$ (Obviously it's so easy to if you plug some values in, but I am trying to find a general solution)
I even tried to find one solution just by playing around with the equation but I doubt it works:
$$a^b(\frac {c^d + 1} {a^b}) + c^d(-1) = 1$$
Since $c$ is even then $c^d$ is even then $(c^d + 1)$ is odd
The only thing left is to check the divisblity
Since $a$ is odd then $a^d$ is odd
But Of, course this entire solution is wrong since $(c^d + 1)$ is not necessarily divisible by $a^d$ but you get idea. I need a general solution like the one I provided.
Btw, I am not asking for a solution, some hint would be more than enough except if the equation I provided is unsolvable, In this can case plz tell me so.
Thanks in advance.
Danny
    Why can't you just write $r=a^b$ and $s=c^d$ and solve $rx+sy=1$ by the Euclidean algorithm? Then $r$ is odd, and $s$ is even. – Dietrich Burde Mar 02 '23 at 20:45
  • @Dietrich Burde then $r = 2k_1 - 1$ and $s = 2k_2$ right? – Danny Mar 02 '23 at 20:49
  • @Ditrich Can I have another hint? – Danny Mar 02 '23 at 20:57
  • There is no closed form solution for general $,a,b,c,d,,$ but you can optimize the computation by using Hensel / Newton methods, e.g. assuming $(a,c)=1$ we have $,x \equiv (a^{-1})^b\pmod{!c^d}$ which can be computed by Hensel lifitng $, a^{-1}\pmod{! c},$ up to $!\bmod c^d,$ by Newton iteration, e.g. see here – Bill Dubuque Mar 02 '23 at 21:12
  • @Bill Dubuque that's what I am talking about. you got my point. I can have this marked as answer – Danny Mar 02 '23 at 21:14
$a^b x + c^d y = 1$ has no closed form solution for general (symbolic) integers $\,a,b,c,d,\,$ but we can optimize solution computation by using Hensel / Newton methods, e.g. assuming as you do that $(a,c)=1$ we have $\,x \equiv (a^{-1})^b\pmod{\!c^d}$ which can be computed very efficiently by Hensel lifting the inverse $\, a^{-1}\pmod{\! c}\,$ up to $\!\bmod c^d\,$ by Newton iteration, e.g. see the worked examples here and in its linked posts.
[comment promoted to answer per OP request]
Bill Dubuque
  • 282,220
