There is a simple formula for obtaining the 'normal' vector N that is perpendicular to two vectors A and B (that define a corner) in 3D: divide the cross product of A and B with its magnitude.
I'm not good at vector math and haven't seen a solution for obtaining B from A and N. All I've been able to do is figure out a relatively convoluted solution based on Roll-Pitch-Yaw. What is the best standard method of solving this?
Just to be clear, I have A, N and an angle from A that would get me to B.
Theo d'Or
  • 173
  • As noted in an answer, it's not clear that the normalized vector $N$ still has enough information to let you figure out the magnitude of $B.$ Are you assuming that $A$ and $B$ also are unit vectors? That might solve that problem. – David K Jan 10 '23 at 05:18
You wrote that you normalize $\vec n$, but you can’t reconstruct $\vec b$ if you do that because then you no longer have any information about the magnitude of $\vec b$. I’ll go with Raad Shaikh and assume that you have $\vec a\times\vec b=\vec n$ and $\vec a\cdot\vec b=d$.
Since the vector $\vec b$ you want is orthogonal to $\vec n$, it’s some linear combination of $\vec a$ and $\vec n\times\vec a$:
$$ \vec b=\lambda\vec a+\mu\vec n\times \vec a\;. $$
You can determine $\lambda$ and $\mu$ by forming the scalar and vector products, respectively, with $\vec a$:
$$\vec a\cdot\vec b=\vec a\cdot\left(\lambda\vec a+\mu\vec n\times \vec a\right)=\lambda|\vec a|^2\stackrel!=d$$
and
$$\vec a\times\vec b=\vec a\times\left(\lambda\vec a+\mu\vec n\times \vec a\right)=\mu\vec a\times\left(\vec n\times \vec a\right)=\mu|\vec a|^2\vec n\stackrel!=\vec n$$
(see vector triple product). Thus
$$\lambda=\frac d{|\vec a|^2}\;,\;\;\mu=\frac1{|\vec a|^2}\;,$$
and
$$ \vec b=\frac{d\vec a+\vec n\times\vec a}{|\vec a|^2}\;. $$
joriki
  • 242,601
    This is so elegant, I'm crying tears of joy reading this! – Raad Shaikh Jan 10 '23 at 01:57
  • Turns out I already answered this seven years ago: https://math.stackexchange.com/questions/1683996/. (I'm not closing as a duplicate because the question here isn't formulated in terms of knowing the cross product and the dot product.) – joriki Jan 17 '23 at 13:27
Let's first put aside some technical details like magnitudes and normalization and all that. You basically have A, N, and the angle between A and B. In other words, you have $\vec{a}$, $\vec{a}\times \vec{b}=\vec{n}, \vec{a}\cdot \vec{b}=d$ (say), and you want to find $\vec{b}$. This is what your situation essentially boils down to.
Note that $\vec{a}\times\vec{b}=\begin{pmatrix}a_1\\a_2\\a_3\end{pmatrix}\times\begin{pmatrix}b_1\\b_2\\b_3\end{pmatrix}=\begin{pmatrix}a_2b_3-a_3b_2\\a_3b_1-a_1b_3\\a_1b_2-a_2b_1\end{pmatrix}=\begin{pmatrix}0&-a_3&a_2\\a_3&0&-a_1\\-a_2&a_1&0\end{pmatrix}\begin{pmatrix}b_1\\b_2\\b_3\end{pmatrix}=\begin{pmatrix}n_1\\n_2\\n_3\end{pmatrix}\\=\vec{\vec{A}}\vec{b}=\vec{n}$,
where $\vec{\vec{A}}$ is that antisymmetric matrix that we made using components of $\vec{a}$ (and $\vec{n}$ is known to us). The reason we can't find $\vec{b}$ right away here is because $\det|\vec{\vec{A}}|=0$, so it's non-invertible. There is no unique solution, there are infinitely many $\vec{b}$'s that satisfy this equation.
However, we also have some extra information in the form $\vec{a}\cdot\vec{b}=d$, or, $a_1b_1+a_2b_2+a_3b_3=d$, which gives us enough to be able to pin down $\vec{b}$ uniquely. This condition can be expressed in matrix form as $\vec{\vec{C}}\vec{b}=\vec{d}$, where
$\vec{\vec{C}}=\begin{pmatrix}a_1&a_2&a_3\\a_1&a_2&a_3\\a_1&a_2&a_3\end{pmatrix},~\vec{d}=\begin{pmatrix}d\\d\\d\end{pmatrix}$
Now, we can combine our two pieces of info (matrix equations) together! Let's try adding them, plain and simple: $(\vec{\vec{A}}+\vec{\vec{C}})\,\vec{b}=(\vec{n}+\vec{d})$
Since $\vec{\vec{A}}+\vec{\vec{C}}$ is invertible (you can verify that its determinant is nonzero), this equation can be solved the usual way: $\vec{b}=(\vec{\vec{A}}+\vec{\vec{C}})^{-1}(\vec{n}+\vec{d})$, which expands to $\begin{pmatrix}b_1\\b_2\\b_3\end{pmatrix}=\begin{pmatrix}a_1&a_2-a_3&a_2+a_3\\a_3+a_1&a_2&a_3-a_1\\a_1-a_2&a_1+a_2&a_3\end{pmatrix}^{-1}\begin{pmatrix}n_1+d\\n_2+d\\n_3+d\end{pmatrix}$
Ta-daa!
Raad Shaikh
  • 1,004
  • This is neat! I studied physics and did lots of stuff with double cross products and the like, and I never came across this nice construction. – joriki Jan 10 '23 at 00:11
    Tbh I just came up with this right now, and I'm half-expecting someone to come along soon and point out some obvious mistake somewhere :p – Raad Shaikh Jan 10 '23 at 00:14
  • I don't see a mistake, but on second thought it does seem a bit of an overkill to solve a $3\times3$ system of equations when you can just form a linear combination of the given vectors (see my answer) – but I still find it a neat construction! – joriki Jan 10 '23 at 01:23
I had a hunch I was missing something simple, and after further study and research found it. The core of the solution is the equation for B:
$$\vec B = \sin (angle) \vec V + \cos(angle) \vec U$$
We obtain U by normalizing A, and V as cross product of N and U. B will be anchored in the same starting point as A and will have a magnitude of 1.
Theo d'Or
  • 173
    This is what I would do, given the kinds of information you are working with (unit $N$, and angle between vectors rather than just their dot product). I think this is equivalent to joriki's construction when you consider the expressions for cross product and dot product in terms of sine and cosine. – David K Jan 10 '23 at 15:29
