Below is a problem from Chapter 22 "Infinite Sequences" of Spivak's Calculus. I've previously asked another question regarding an incorrect attempt at solving item $b$ of this problem. Now I am interested in the solution manual solution.
17.(a) Prove that if $\lim\limits_{n\to\infty} [a_{n+1}-a_n]=l$, then $\lim\limits_{n\to\infty} \frac{a_n}{n}=l$.
(b) Suppose that $f$ is continuous and $\lim\limits_{x\to\infty} [f(x+1)-f(x)]=l$. Prove that
$$\lim\limits_{x\to\infty} \frac{f(x)}{x}=l$$
Hint: Let $a_n$ and $b_n$ be the $\inf$ and $\sup$ of $f$ on $[n,n+1]$.
Here is the solution manual solution to part $(b)$
The hypothesis $\lim\limits_{x\to\infty} [f(x+1)-f(x)]=l$ implies that $a_n$ and $b_n$, the $\inf$ and $\sup$ of $f$ on $[n,n+1]$, satisfy $\lim\limits_{n\to\infty} [a_{n+1}-a_n]=l$ and $\lim\limits_{n\to\infty} [b_{n+1}-b_n]=l$.
So by part $(a)$, we have $\lim\limits_{x\to\infty} a_n/n=\lim\limits_{x\to\infty} b_n/n=l$, which implies that $\lim\limits_{x\to\infty} f(x)/x=l$.
How do we conclude
$$\lim\limits_{n\to\infty} [a_{n+1}-a_n]=l$$
and
$$\lim\limits_{n\to\infty} [b_{n+1}-b_n]=l$$
from
$$\lim\limits_{x\to\infty} [f(x+1)-f(x)]=l$$
xoux
  • 5,079
  • @OliverDíaz I am in the process of going through that solution. It seems substantially more complex than this one from the solution manual, however, right? Or is it simply the case that this solution manual solution has omitted a bunch of intermediate complicated steps used to prove the question I am currently asking? – xoux Oct 20 '22 at 07:17
  • @OliverDíaz Are you referring to $a_n\leq f(x)\leq f(x+1)\leq b_n$ then $f(x+1)-f(x)\leq b_n-a_n$? – xoux Oct 20 '22 at 07:49
  • @AnneBauval: I meant $a_n+\ell-\varepsilon\leq f(x)+\ell-\varepsilon<f(x+1) < f(x)+\ell+\varepsilon\leq b_n+\ell+\varepsilon$. Then of course $a_n+\ell-\varepsilon\leq a_{n+1}\leq b_{n+1}\leq b_n+\ell+\varepsilon$ follows. – Mittens Oct 20 '22 at 08:02
  • @AnneBauval You say that we do not have $f(x)\leq f(x+1)$. Did you mean, instead, that we do have this? After all it means that $f(x+1)-f(x)\geq 0$, which happens given that $\lim\limits_{x\to\infty} [f(x+1)-f(x)]=l$. – xoux Oct 20 '22 at 08:08
  • Is the intuition correct that above some value $y$ the graph of $f$ starts resembling something linear and increasing? – xoux Oct 20 '22 at 08:09
  • @OliverDíaz I still neither agree with your misleading "Yes, that is correct" nor with your "$a_n<a_{n+1}\leq b_{n+1}\leq b_n$". Oh I see you just deleted both. – Anne Bauval Oct 20 '22 at 08:12
    We do not have $f(x)\leq f(x+1)$. This $f(x+1)-f(x)\ge0$ is not implied by the existence of $\lim\limits_{x\to\infty}\left(f(x+1)-f(x)\right).$ – Anne Bauval Oct 20 '22 at 08:16
    @AnneBauval: Notice my last comment addressed to you. I corrected what I said. I am not claiming $a_n\leq a_{n+1}\leq b_{n+1}\leq b_n$. – Mittens Oct 20 '22 at 08:16
  • @evianpring: See my answer below. It does not use Stolz-Cesaro and uses only definition of limit. – Koro Oct 20 '22 at 08:37
    We do not have that "above some value the graph of $f$ starts resembling something linear and increasing". E.g. $f(x)=\sin(2\pi x).$ – Anne Bauval Oct 20 '22 at 08:53
4 Answers4
Part(b) follows from part (a).
Here I discussed two solutions: one I obtained by following the link given in Spivak's book (solution 1), and an explanation of the solution in the user's manual described in the OP (solution 2). At the end I also add simple solution to part (a) of the problem in the OP.
Solution 1: First notice that \begin{align} \frac{f(x)}{x}=\frac{f(x)-f(\lfloor x\rfloor)}{x} +\frac{\lfloor x\rfloor}{x}+ \frac{f(\lfloor x\rfloor)}{\lfloor x\rfloor} \end{align} where $\lfloor x\rfloor$ is the largest less or equal to $x$. Since $\lim_{x\rightarrow\infty}f(x+1)-f(x)=\ell$, $f(\lfloor x\rfloor)/\lfloor x\rfloor \xrightarrow{x\rightarrow\infty}\ell$ by part (a). Thus, it is enough to show that \begin{align} \lim_{x\rightarrow\infty}\frac{f(x)-f(\lfloor x\rfloor)}{x}=0\tag{0}\label{zero} \end{align} Being that that $f$ is bounded in any compact interval, for any $n\in\mathbb{N}$ $\alpha_n=\inf_{x\in[n,n+1]}f(x)$ and $\beta_n=\sup_{x\in[n,n+1]}f(x)$ are finite. Then, $|f(x)-f(\lfloor x\rfloor)|\leq \beta_n-\alpha_n$ for $n=\lfloor x\rfloor$.
Give $\varepsilon>0$, there is $N$ large enough such that $x\geq N$ implies \begin{align} f(x)+\ell-\varepsilon<&f(x+1)<f(x)+\ell+\varepsilon\tag{1}\label{one}\\ f(x+1) -\ell-\varepsilon &< f(x)<f(x+1)-\ell+\varepsilon\tag{2}\label{two}& \end{align} From \eqref{one} and \eqref{two} we obtain \begin{align} \alpha_n+\ell-\varepsilon&\leq \alpha_{n+1}\leq \beta_{n+1}\leq \beta_n+\ell+\varepsilon,\tag{3}\label{three}\\ \alpha_{n+1}-\ell-\varepsilon&\leq \alpha_n\leq \beta_n\leq \beta_{n+1}-\ell+\varepsilon,\tag{4}\label{four} \end{align} for all $n\geq N$ and so, \begin{align} \alpha_n-\beta_n-2\varepsilon\leq \beta_{n+1}-\alpha_{n+1}\leq \beta_n-\alpha_n+2\varepsilon\tag{5}\label{five} \end{align} Iterating this inequality yields
\begin{align} \beta_N-\alpha_N - (n-N+1)2\varepsilon\leq \beta_{n+1}-\alpha_{n+1}\leq (\beta_N-\alpha_N)+ (n-N+1)2\varepsilon\tag{6}\label{six} \end{align} It follows that for all $x\geq N+1$, $$\frac{|f(x)-f(\lfloor x\rfloor)|}{x}\leq \frac{\beta_N-\alpha_N}{x}+\frac{\lfloor x\rfloor -N}{x}2\varepsilon$$ This means that $\limsup_{x\rightarrow\infty}\frac{|f(x)-f(\lfloor x\rfloor)|}{x}\leq2\varepsilon$ for any $\varepsilon>0$, and \eqref{zero} follows.
Solution 2: As for what is in the solution's manual, notice that from \eqref{three} and \eqref{four} \begin{align} \ell-\varepsilon&\leq \alpha_{n+1}-\alpha_n\leq \ell+\varepsilon\\ \ell-\varepsilon&\leq \beta_{n+1}-\beta_n\leq \ell+\varepsilon \end{align} for all $n\geq N$. This implies that $$\lim_n(\beta_{n+1}-\beta_n)=\ell=\lim_n(\alpha_{n+1}-\alpha_n)$$ By part (a) of the problem $$\lim\frac{\alpha_n}{n}=\ell=\lim_n\frac{\beta_n}{n}$$ wich also implies that $\lim_{x\rightarrow\infty}\frac{f(x)}{x}=\ell$.
Part(a) follows by taking Cesaro sums: since $a_{n+1}-a_n\xrightarrow{n\rightarrow\infty}\ell$, $\ell=\lim_n\frac1n\sum^{n-1}_{k=0}(a_{k+1}-a_k)=\lim_n\frac{a_n-a_0}{n}=\ell$.
Mittens
  • 46,352
  • This is a useful answer in the context of my previous question that regarded general solutions and I am laboring to go through it. However, the current question is very specific: for the specific solution from the solution manual, how does one go from $\lim\limits_{x\to\infty} [f(x+1)-f(x)]=l$ to $\lim\limits_{n\to\infty} [a_{n+1}-a_n]=l$ and $\lim\limits_{n\to\infty} [b_{n+1}-b_n]=l$? – xoux Oct 20 '22 at 07:25
  • Why does part $(a)$ make it enough to show $(0)$? – xoux Oct 20 '22 at 08:50
  • @evianpring: Becase (1) taking the limit over the integers $\lim_n f(n)/n=\ell$ by virtue of $\lim_n(f(n+1)-f(n))=\ell$; (2) taking the limit over reals, $\lim_{x\rightarrow\infty}x/\lfloor x\rfloor =1$. I edited my solution for the last time to address also the solution in your manual using my main arguments. Hope this helps. – Mittens Oct 20 '22 at 09:19
Applying the general property $$\inf_{x\in A} (a(x)+b(x))\ge\inf_{x\in A} a(x)+\inf_{x\in A} b(x)$$ to $A=[n,n+1]$, $a(x)=f(x+1)-f(x)$ and $b=f$, we get: $$a_{n+1}\ge\inf_{x\in[n,n+1]}\left(f(x+1)-f(x)\right)+a_n.$$ Similarly, $$a_n\ge\inf_{x\in[n,n+1]}\left(f(x)-f(x+1)\right)+a_{n+1}.$$ These two inequalities are summarized in $$\inf_{x\in[n,n+1]}\left(f(x+1)-f(x)\right)\le a_{n+1}-a_n\le-\inf_{x\in[n,n+1]}\left(f(x)-f(x+1)\right).$$ From this, using the equality $-\inf_{x\in[n,n+1]}\left(f(x)-f(x+1)\right)=\sup_{x\in[n,n+1]}\left(f(x+1)-f(x)\right)$ and the hypothesis $\lim\limits_{x\to\infty}\left(f(x)-f(x+1)\right)=l$, we conclude: $$\lim\limits_{n\to\infty}\left(a_{n+1}-a_n\right)=l.$$ The similar result for $b_n$ may be proved the same way, or deduced from the result for $a_n$ by changing $f$ to $-f.$
Anne Bauval
  • 49,005
    +1 this is the cleanest way – FShrike Oct 20 '22 at 08:02
  • Would you mind if I edit your answer to number your equations? In the inequality
    shouldn't it be a $\leq$ sign?
    – xoux Oct 20 '22 at 08:13
  • Please don't change. – Anne Bauval Oct 20 '22 at 08:21
  • The inequality $a_{n+1}\ge\inf_{x\in[n,n+1]}\left(f(x+1)-f(x)\right)+a_n.$ isn't obvious to me.
    $\inf_{x\in[n,n+1]}\left(f(x+1)-f(x)\right)$ means that we take every point $x$ in $[n,n+1]$ and compare $f(x)$ to $f(x+1)$ and take the smallest, call it $\gamma$.
    Then we are saying that the difference between $a_n$ and $a_{n+1}$, which is the difference between the smallest value of $f$ in $[n,n+1]$ and in $[n+1,n+2]$, is larger than $\gamma$.
    Is this obvious? I can't come up with a counterexample, but it doesn't follow crystal clear from the first line.
    – xoux Oct 20 '22 at 08:42
Given that $a_n:=\inf f[n,n+1], b_n=\sup f[n,n+1] .$
Well-definedness: $a_n,b_n$ are well defined since $f$ is continuous and $[n,n+1]$ is a compact set (this is same as closed and bounded in $\mathbb R$).
To prove: $\lim_n (a_{n+1}-a_n)=l=\lim_n (b_{n+1}-b_n),$ which by definition of limit is equivalent to proving that "Given any $\epsilon>0$, there exists $N\in \mathbb N$ such that $n\ge N\implies -\epsilon\lt a_{n+1}-a_n-l\lt \epsilon.$"
To achieve this, first fix an $\epsilon>0$.
Let's break down rest of the solution in steps:-
Step (1): (Choosing large $x$) Since $\lim_{x\to \infty}(f(x+1)-f(x))=l$, there exists $N\in \mathbb N$ such that $x\ge N\implies -\epsilon/2\lt f(x+1)- f(x)-l\lt \epsilon/2.$
Step(2):(Estimating $a_{n+1}-a_n$ from above) Note that for all $n\ge 2N,$
By definition of infimum, there exists $x_n\in [n,n+1]$ such that $a_n+\epsilon/2\gt f(x_n).$ It follows that $$\begin{align} a_{n+1}-a_n-l \le &a_{n+1}-f(x_n)-l+\epsilon/2\\ \le& f(x_n+1)-f(x_n)-l+\epsilon/2\\ \overbrace{\le }^{\text{ By step $(1)$}}& \epsilon/2+\epsilon/2=\epsilon \end{align}$$
Step (3):(Estimating $a_{n+1}-a_n$ from below) Note that for all $n\ge 2N,$
By definition of infimum, there exists $y_n\in [n+1,n+2]$ such that $a_{n+1}+\epsilon/2\gt f(y_n).$ It follows that $$\begin{align} a_{n+1}-a_n-l \ge & f(y_n)-a_n-l-\epsilon/2\\ \ge& f(y_n)-f(y_n-1)-l-\epsilon/2\\ \overbrace{\ge }^{\text{ By step $(1)$ again}}& -\epsilon/2-\epsilon/2=-\epsilon \end{align}$$
It follows by step (2) and (3) that: Given any $\epsilon>0$, there exists $N\in \mathbb N$ such that $n\ge 2N\implies -\epsilon\lt a_{n+1}-a_n-l\lt \epsilon.$ This proves the statement for $(a_{n+1}-a_n)$. The statement is similar for $(b_{n+1}-b_n)$, which I leave up to you.
Koro
  • 11,766
Perhaps this answer does not fit, because I prefer not to follow Spivak's suggestion.
Let $g(x)=f(x)-lx.$ Then $\displaystyle\lim_{x\to \infty} [g(x+1)-g(x)]=0.$ We are done once we get $$\lim_{x\to \infty}{g(x)\over x}\overset{?}{=}0\quad (*)$$ Fix $\varepsilon >0.$ There exists a number $x_0\ge 1$ such that $$|g(x+1)-g(x)|<\varepsilon,\qquad x+1>x_0$$ For $x>x_0$ let $n_x$ denote the smallest nonnegative integer such that $x-n_x\le x_0.$ Hence $x-n_x+1>x_0.$ Thus $$ n_x<x-x_0+1\le x$$ We have $$\displaylines{g(x)=[g(x)-g(x-1)]+[g(x-1)-g(x-2)]\\ \qquad \qquad \qquad +\ldots +[g(x-n_x+1)-g(x-n_x)]+g(x-n_x)}$$ Therefore $$|g(x)|\le n_x\varepsilon +\max_{0\le t \le x_0}|g(t)|$$ Hence for $\displaystyle c:=\max_{0\le t\le x_0}|g(t)|$ we have $${|g(x)|\over x}\le {n_x\over x}\varepsilon+{1\over x}c\le \varepsilon +{1\over x}c,\quad x>x_0-1$$ Finally $${|g(x)|\over x}<2\varepsilon,\qquad x>x_0-1,\ x>{c\over \varepsilon}$$ This completes the proof of $(*).$
  • (+1) a similar solution was posted before in a link tied to this problem, but your posting is much clearer. – Mittens Oct 20 '22 at 23:40
