I'm using the convention that the fourier transform of a function $f(\vec x$) is$$\frac{1}{(2\pi)^{3/2}}\int{d^3x\: e^{-i\vec k\cdot \vec x}f(\vec x)}$$ I'm now fourier transforming the function $$f(\vec x)=\frac{1}{\sqrt{\pi a^3}}e^{-r/a}$$ with $r:= \sqrt{x^2+y^2+z^2} $. The result I get is $$\frac{\sqrt{(2a)^3}}{\pi}\frac{1}{(1+(ka)^2)^2}, \: k:=\sqrt{k_1^2+k_2^2+k_3^2} $$ which I think should be correct. Once I do the backwards fourier transform (which looks exactly as the fourier transform just with an integration over $\vec k$ and $e^{i\vec k\cdot \vec x}$ instead of the negative exponent), I'm running into trouble. When I first start the inverse transformation I switch into spherical coordinates and after a few steps I arrive at: $$\frac{\sqrt{(2a)^3}}{\pi} \sqrt{\frac{2}{\pi}}\frac{1}{r} \frac{2}{a^4}\int _0^\infty{ dk \frac{\sin(kr) k}{(k-\frac{i}{a})^2(k+\frac{i}{a})^2}}$$ I now want to solve this using the residue theorem. Since the function is even I can simply put an $\frac{1}{2}$ in front and integrate from $-\infty$ to $+\infty$ instead. Then the 2-fold degenerate complex zeros of the denominator are of course $z_1 = \frac{i}{a}$ and $z_2=-\frac{i}{a}$, with the following residues $$Res(z_{1/2})=\mp \frac{1}{4}i a r \cosh{r/a}$$ If I understand the way to do these kind of integrals correctly, then I have to close the integral in the complex plane making it a contour integral and depending on wheter I close the loop in the positive or negative complex plane I will have to use the residue of $z_1$ or $z_2$ respectively, since that's the one that gets enclosed by the contour. But if I do it like that I simply get some kind of $\cosh$ for my inverse fourier transform and not the $e^{-r/a}$ that I started with.
I assume I'm just missing something about how to correctly solve these kind of complex integrals, since if I could somehow combine the two residues I could get the exponential I want out of them.
Any help or tipps are greatly appreciated, thank you!
    The problem is that your integral along the extended contour does not go to 0. In complex numbers $\sin kz$ is not bounded between $-1$ and $1$ – Andrei Aug 21 '21 at 23:03
    As a side comment, I just wrote here (https://math.stackexchange.com/questions/4220006/computing-the-fourier-transform-of-exponential-decay-in-mathbbr2/4220125#4220125) a method without complex analysis for the same integral ;) – LL 3.14 Aug 22 '21 at 21:31
As mentioned in my comment, the integral over the part of the contour where $|z|\to\infty$ is not $0$. If you want to integrate over the upper contour, use $e^{ikr}$ instead of $\sin kr$. Then, in the upper half of the plane, $k$ becomes $|k|e^{i\phi}$. Then $$|e^{ikr}|=|e^{i|k|r(\cos\phi+i\sin\phi)}|=|e^{i|k|r(\cos\phi}e^{-|k|r\sin\phi}|$$ When $|k|\to \infty$ the second exponential goes to $0$. The absolute value of the first exponential is always $1$. Then notice $$\int_{-\infty}^\infty\frac{ke^{ikr}}{(1+(ka)^2)^2}dk=\int_{-\infty}^0\frac{ke^{ikr}}{(1+(ka)^2)^2}dk+\int_{0}^\infty\frac{ke^{ikr}}{(1+(ka)^2)^2}dk$$ In the first integral replace $k$ with $-k$. Can you continue from here?
EDIT $$\int_{-\infty}^\infty\frac{ke^{ikr}}{(1+(ka)^2)^2}dk=\int_0^\infty\frac{k(e^{ikr}-e^{-ikr})}{(1+(ka)^2)^2}dk=2i\int_0^\infty\frac{k}{(1+(ka)^2)^2}\frac{(e^{ikr}-e^{-ikr})}{2i}dk$$ The last fraction is $\sin(kr)$. Then using residue theorem, and the fact that on the upper contour the integral is zero, we get: $$2i\int_0^\infty\frac{k\sin(kr)}{(1+(ka)^2)^2}=2\pi i \frac 14 ar e^{-r/a}$$ Notice that you have $2i$ on both sides. So when multiply with your prefactors you get $$\frac{\sqrt{(2a)^3}}{\pi} \sqrt{\frac{2}{\pi}}\frac{1}{r} \frac{2}{a^4}\frac 14\pi are^{-r/a}=\frac2{\sqrt{\pi a^3}}e^{-r/a}$$ This is your original function, up to a factor of $2$, that either you or I have missed in the calculation.
Andrei
  • 39,869
  • Thank you very much for your answer! So in order to extend my integral to the contour, what kind of property has to be fullfilled? I read online that the function in the integral times $k$ to the power of the zero in the denominator has to vanish at $|k|\to \infty$, is that correct? – DeltaChief Aug 22 '21 at 17:21
  • And I get to the point where I have $\int_{-\infty}^\infty\frac{ke^{ikr}}{(1+(ka)^2)^2}dk$, but I don't get where your hint on separating the integral into two parts leads. When I just use the residue theorem for the Integral as it is and close in the upper half I almost get something correct, but I also are left with a factor of $i$, which doesn't match up with my starting function. My residue that I get for that Integral is $\frac{1}{4}a\exp^{-r/a}r$ – DeltaChief Aug 22 '21 at 17:24
    I've updated the answer. I am off by a factor of 2, that it might be from either my calculations or yours. – Andrei Aug 22 '21 at 19:17
    As for the property of the integral, the integrand has to be on the order less than $k^{-1}$. If the integrand is $C/k$, then the integral on the contour at infinity is a constant. – Andrei Aug 22 '21 at 19:21
  • ah ok that makes sense, because then if i would to a path integral and go around the outside of the circle at infinity i would get an extra factor of k by switching to polar coordinates. Thank you! – DeltaChief Aug 22 '21 at 20:02
    @DeltaChief You are welcome. I hope you can find the extra factor of 2. – Andrei Aug 22 '21 at 20:03
