Consider following quadratic equation whose roots are $a$ and $b$.
$$x^2 +ax +b = 0 $$
We need to find $a$ and $b$ provided that $a,b\neq0$
So it seems a pretty easy question and it is,
From product of roots we get $a=1$ From sum of roots we get $b=-2$
Now I decided solve with an other way as follows-
Since $a$ and $b$ are roots of equation, therefore they will satisfy it as follows-
$ a^2 + a^2 + b = 0$ and hence $2a^2=-b$
$b^2 + ab +b=0$
Substituting value of $b$ we get
$4a^4-2a^3-2a^2=0$
Since $a\neq0$ solving for a gives two values $a=1$ and $a=-1/2$
and therefore corresponding values of $b$ as $-2,-1/2$ and hence we get following two quadratic equations
$x^2+x-2=0$ and $2x^2-x-1=0$
The first one has roots $(1,-2)=(a,b)$ , therefore we got one answer
but second one has roots $(1,-1/2)\neq(a,b)$
Why does this happens with second equations that it's roots are not equal to $a,b$
dxiv
  • 77,867
Lalit Tolani
  • 3,454
$a^2 + a^2 + b = 0$
$b^2 + ab +b=0$
This system of equations does indeed follow from the problem statement, but it is not equivalent to it. Reason is that the problem assumes $a,b$ to be the roots of the quadratic, with emphasis on the plural of "roots".
  • The first solution based on Vieta's formulas preserves this assumption, and provides the correct result.
  • But the substitution that leads to the system of equations loses the distinction that $a,b$ must be the two roots of the quadratic, and allows for $a,b$ to be one and the same root.
In other words, extraneous solutions may be introduced among the solutions of the system, where $a$ is a root and $b=a$. Which is precisely what happened in this case with $a = b = -1/2$.
Therefore, the solutions to the system are not guaranteed to satisfy the original problem, and must be verified each. (Note: it is not safe to automatically reject any solution with $a=b$, because they could be equal in case a real solution existed which turned out to be a quadratic with a double root.)
dxiv
  • 77,867
  • Elaborated some more in my other answer here. – dxiv May 24 '21 at 23:45
    thankyou for solving my problem fabulously in both your answers – Lalit Tolani May 25 '21 at 01:59
    @lalittolani Yours was a well asked question. It's good that you tried it, and even better that you noticed the inconsistency. The fallacy here was of a more subtle variety than the usual algebraic pitfalls. – dxiv May 25 '21 at 02:20
