I have to prove that $$\left[1+\frac{1}{(n+1)^2}\right]^{(n+1)^2}-\left[1+\frac{1}{n^2}\right]^{n^2}>0$$ for $n\geq 2$.
I checked the base case and it holds true for $n=2$.
Assume it is true for $n$ then,
$$\left[1+\frac{1}{(n+1)^2}\right]^{(n+1)^2}>\left[1+\frac{1}{n^2}\right]^{n^2}$$
How should I proceed from here. Any help is appreciated.
Blue
  • 83,939
Natasha J
  • 835
  • Well, that's a right mess of a formula, true enough. For induction, you assume it works for k and show it works for k+1. Frankly I wouldn't use induction here, I'd call $n$ as $x$ and work calculus to try to prove it. But for induction...maybe some intermediate inequalities? Try to make small changes in the formulas to make them simpler. – RobertTheTutor Apr 20 '21 at 03:46
  • Trust me, I have been trying for past one and a half hour. And still I am nowhere!! – Natasha J Apr 20 '21 at 03:48
  • have you tried working back from the n+1 step? to see where the assumption may be useful. – Nyra Apr 20 '21 at 03:53
  • I did. Got stuck there too. – Natasha J Apr 20 '21 at 03:58
    Please use $\frac{a}{b}$ to express $\frac{a}{b}$, so that mathSE reviewers won't have to guess your intent of $(a + b/c).$ Is it $\frac{a+b}{c}$ or $a + \frac{b}{c}$? Please edit your own question directly, rather than responding with a comment. – user2661923 Apr 20 '21 at 03:59
    This is so very similar to proving that $(1 + \frac 1{n+1})^n$ is increasing and bounded above (which is essential in the definition of Euler's constanat $e$) that you should study that. – fleablood Apr 20 '21 at 04:05
  • @NatashaJ FYI, this answer might be somewhat useful. – John Omielan Apr 20 '21 at 04:12
  • In my book, $(1+1/(n+1))$ is solved by AM- GM inequality. I tried to do it that way, but it wasn't helpful. – Natasha J Apr 20 '21 at 04:14
Observation:
Let's say
$a_n = (1 + \frac{1}{n})^n$
and
$b_n = (1 + \frac{1}{n^2})^{n^2}$
Obviously, $b_n = a_{n^2}$ , and we can easily prove that $a_n$ is increasing (see here).
So, $b_{n+1} = a_{(n+1)^2} > a_{n^2} = b_n$
Middle inequality holds because $(n+1)^2 > n$ and $a_n$ is increasing.
So, you are actually trying to prove that $a_n$ is increasing but in the set of natural squares, ie $1,4,9,16,25,\dots$
In order to use pure induction, the idea is to link your n-th term (which is basically $n^2$) with his previous natural number, ie $n^2-1$.
Doing so, we get
$(1+\frac{1}{n^2})^{n^2} > (1+\frac{1}{n^2-1})^{n^2-1} \Leftrightarrow$
$\Big(\frac{1+\frac{1}{n^2}}{1+\frac{1}{n^2-1}}\Big)^{n^2} > (1+\frac{1}{n^2-1})^{-1} \Leftrightarrow$
$(1-\frac{1}{n^4})^{n^2} > 1 - \frac{1}{n^2} $
Which holds because of the Bernoulli's inequality (see here)
Now, doing this step $2n-1$ times you get
$(1+\frac{1}{n^2})^{n^2} > (1+\frac{1}{n^2-2n+1})^{n^2-2n+1} \Leftrightarrow$
$(1+\frac{1}{n^2})^{n^2} > (1+\frac{1}{(n-1)^2})^{(n-1)^2}$
I'm not sure how one could proceed with induction, so I'll present an alternate proof that uses the methods of calculus. I learned it by solving Problem 90 from Section 11.1 of James Stewart's Calculus: Early Transcendentals (8e), and it definitely qualifies as one of my all-time favorite proofs!
Consider the sequence $a_n=\left(1+\frac{1}{n}\right)^n$. It's clear that $n^2<(n+1)^2$ for every $n\geq 1$, so if we can prove that $a_n$ is strictly increasing, that is
$$\left(1+\frac{1}{n}\right)^n<\left(1+\frac{1}{n+1}\right)^{n+1}$$
for all $n\geq 1$, your inequality immediately follows.
Given some integer $n\geq 1$, consider the function $f(x)=x^{n+1}$ defined over $[0,\infty)$. This function is differentiable over $(0,\infty)$, so given any pair of numbers $a,b\in\mathbb{R}$ with $0\leq a<b$, the mean value theorem implies that there is a $c\in(a,b)$ satisfying
$$\frac{f(b)-f(a)}{b-a}=f'(c)$$
that is,
$$\frac{b^{n+1}-a^{n+1}}{b-a}=(n+1)c^n$$
We know that $n\geq 1$, so $f'$ must be strictly increasing. Thus,
$$\frac{b^{n+1}-a^{n+1}}{b-a}=(n+1)c^n=f'(c)<f'(b)<(n+1)b^n$$
We now rearrange the resulting inequality
\begin{align*} \frac{b^{n+1}-a^{n+1}}{b-a}<(n+1)b^n &\iff b^{n+1}-a^{n+1}<(b-a)(n+1)b^n\\ &\iff b^{n+1}-(b-a)(n+1)b^n<a^{n+1}\\ &\iff b^{n}\left[b-(nb+b-na-a)\right]<a^{n+1}\\ &\iff b^{n}(b-nb-b+na+a)<a^{n+1}\\ &\iff b^{n}\left[(n+1)a-nb\right]<a^{n+1}\\ \end{align*}
Now we substitute $a=1+\frac{1}{n+1}$ and $b=1+\frac{1}{n}$ This is justified because the inequality holds for $0\leq a<b$ and $0<1+\frac{1}{n+1}<1+\frac{1}{n}$.
$$\left(1+\frac{1}{n}\right)^{n}\left[(n+1)\left(1+\frac{1}{n+1}\right)-n\left(1+\frac{1}{n}\right)\right]<\left(1+\frac{1}{n+1}\right)^{n+1}$$
$$\iff \left(1+\frac{1}{n}\right)^{n}\left[n+1+1-n-1\right]<\left(1+\frac{1}{n+1}\right)^{n+1}$$
$$\iff \left(1+\frac{1}{n}\right)^{n}<\left(1+\frac{1}{n+1}\right)^{n+1}$$
This proves that $a_n$ is strictly increasing, which immediately implies that
$$\left(1+\frac{1}{n^2}\right)^{n^2}<\left(1+\frac{1}{(n+1)^2}\right)^{(n+1)^2}$$
or
$$\left(1+\frac{1}{(n+1)^2}\right)^{(n+1)^2}-\left(1+\frac{1}{n^2}\right)^{n^2}>0$$
Alann Rosas
  • 6,553
