I ask for help from specialists in differential equations, dynamical systems, optimal control and general control theory;
I have the following system of differential equations:
\begin{cases} \frac{dx(t)}{dt}=G(t) \\ \frac{dz(t)}{dt}+z(t)=\frac{df}{dt} \\ \frac{dG(t)}{dt}+G(t)=z(t) \cdot \alpha \sin(\omega t) \\ \frac{dH(t)}{dt}+H(t)=z(t) \cdot (\frac{16}{\alpha^2}(\sin(\omega t)-\frac{1}{2})) \\ \frac{dX(t)}{dt}+X(t)=\frac{dx(t)}{dt} \end{cases}
where, $x,z,G,H,X$ - variables; $f=-(x(t)+\alpha \sin(\omega t)-x_e)^2$; $\alpha, \omega$ - parameters.
As an output $y$, I assign:
$y=\tanh(k \cdot H(t))$
As an reference signal $r_1$, I assign:
$r_1=-1$
As an constant time $p_1$, I assign:
$p_1=-1$
Well, I tried to program this in the Mathematica program and ran into a difficulty that I can't get over yet. Question: in which of the equations should the control signal $u(t)$ be placed?
I chose the first equation, then the original system of equations will look like this:
\begin{cases} \frac{dx(t)}{dt}=G(t)+u(t) \\ \frac{dz(t)}{dt}+z(t)=\frac{df}{dt} \\ \frac{dG(t)}{dt}+G(t)=z(t) \cdot \alpha \sin(\omega t) \\ \frac{dH(t)}{dt}+H(t)=z(t) \cdot (\frac{16}{\alpha^2}(\sin(\omega t)-\frac{1}{2})) \\ \frac{dX(t)}{dt}+X(t)=\frac{dx(t)}{dt} \end{cases}
Clear["Derivative"]
ClearAll["Global`*"]
Needs["ParallelDeveloper"]
S[t] = [Alpha] Sin[[Omega] t]
M[t] = 16/[Alpha]^2 (Sin[[Omega] t] - 1/2)
f = -(x[t] + S[t] - xe)^2
Parallelize[
asys = AffineStateSpaceModel[{x'[t] == G[t] + u[t],
z'[t] + z[t] == D[f, t], G'[t] + G[t] == z[t] S[t],
H'[t] + H[t] == z[t] M[t],
1/k X'[t] + X[t] == D[x[t], t]}, {{x[t], xs}, {z[t], 0.1}, {G[t],
0}, {H[t], 0}, {X[t], 0}}, {u[t]}, {Tanh[k H[t]]}, t] //
Simplify]
pars1 = {Subscript[r, 1] -> -1, Subscript[p, 1] -> -1}
Parallelize[
fb = AsymptoticOutputTracker[asys, {-1}, {-1, -1}] // Simplify]
pars = {xs = -1, xe = 1, [Alpha] = 0.3, [Omega] = 2 Pi*1/2/Pi,
k = 100, [Mu] = 1}
Parallelize[
csys = SystemsModelStateFeedbackConnect[asys, fb] /. pars1 //
Simplify // Chop]
plots = {OutputResponse[{csys}, {0, 0}, {t, 0, 1}]}
At the end, I get an error.
At t == 0.005418556209176463`, step size is effectively zero; \
singularity or stiff system suspected
It seems to me that this is due to the fact that either in the system there is a $\csc$ somewhere, or I have put the control input signal in the wrong equation. I need the support of a theorist who can help me choose the right sequence of actions to solve the problem.
I would be glad to any advice and help.
AffineStateSpaceModellinearizes the nonlinear equations about an operating point. Are you sure the linearization is controllable? Also doesn't look like it supports your time varying model... – Rollen S. D'Souza Apr 18 '21 at 16:30I discovered something. The system is controlled if the input $u(t)$ is set to either the first or the third equation. In both cases, the system is not observable at the output if the variable $H(t)$ is used as an output $y$, but in combination with other variables (I chose $y=X(t)-G(t)-H(t)$) the system is controllable and observable. I am afraid that variable coefficients with $\sin(\omega t)$ introduce the singularity into the system.
– ayr Apr 19 '21 at 03:41https://math.stackexchange.com/questions/4114416/finite-time-criterion-for-ode
– ayr Apr 24 '21 at 06:10
