Assume that $f: \mathbb{R}^n \rightarrow \mathbb{R} $ is Lipschitz continuous with constant $M$ and that $S \subseteq \mathbb{R}^n$ is closed. Show that for $\lambda > M$ problem of minimizing $f(x) + \lambda d(x, S)$, where $d(x,S)$ is a distance from $x$ to $S$ have the same solutions as problem of minimizing $f(x)$ over $S$.
I know that because $S$ is closed, then there exists $b \in S$ such that $d(x, S) = d(x, b)$, Because I now have some $b$ I can use Lipschitz condition to get $d(f(x), f(b)) \leq M d(x, b)$. But I don't see how to proceed further or if this actually gives something useful.
Edit: I have tried the following, but I got stuck
Let $x_S$ be the solution to the problem of minimizing $f(x)$ over $S$. Because $x_S \in S$ we have $d(x_S, S) = 0$.
- Assume $\hat x \in S$ is a solution to the problem of minimizing $f(x) + \lambda d(x, S)$. Because $\hat x \in S$ we have $d(\hat x, S) = 0$. Because it is a solution to the problem of minimizing $f(x) + \lambda d(x, S)$ we have that $f(\hat x) < f(x_S)$. But both points are in $S$ and $x_S$ minimizes $f(x)$ over $S$, so we have contradiction.
- Assume $\hat x \notin S$ is a solution to the problem of minimizing $f(x) + \lambda d(x, S)$. Then because $S$ is closed we have $d(\hat x, S) > 0$ (If $S$ wasn't closed then points from boundary of $S$ wouldn't be in $S$ and their distance to $S$ would be $0$). So we have $$f(\hat x) + \lambda d(\hat x, S) < f(x_S) + \lambda d(x_S, S) = f(x_S)$$ $$f(\hat x) - f(x_S) < - \lambda d(\hat x, S)$$ Both sides are negative, so by taking abolute value on both sides we get $$|f(\hat x) - f(x_S)| > \lambda d(\hat x, S) > M d(\hat x, S)$$ Basically I wanted to get a contradiction with Lipschitz condition but for that I would need something like $d(\hat x, S) = d(\hat x, x_S)$ which I am not sure I can get. Buth this is what I have tried.
Edit 2:
Now I understand that I can frame minimization of $f(x)$ over $S$ as $$\text{minimize } f(x)\\ \text{such that }d(x,S) = 0$$
Then $$\text{minimize} f(x) + \lambda d(x, S)$$ looks like a Lagrangian. Basically I think this changes the question to question about strong duality of this problem. Maybe.
