Let $V$ be an integrable module over a Kac-Moody algebra. Then $\dim V_\lambda=\dim V_{w(\lambda)}$ for each $\lambda\in\mathfrak{h}^*$ and $w\in W$ (the Weyl group).
It's a proposition stated in Kac's book Infinite dimensional Lie algebras, however he just states it follows form the two following lemmas:
- $\textrm{ad}\ e_i$ and $\textrm{ad}\ f_i$ are locally nilpotent over a Kac-Moody algebra.
- If $\lambda$ is a weight of $V$, then $\lambda-\lambda(\alpha_i^\vee)\alpha_i$ is also a weight of the same multiplicity.
However I don't see why this is the case?
Also the first lemma is pretty clear to me, but I don't see why the second lemma holds?
I'm also happy to see, if there is another way of proving this. Maybe it can somehow be reduced to the finite-dimensional case like when showing that "The module $L(\Lambda)=M(\Lambda)/N(\Lambda)$ (the quotient of a Verma module) over a Kac-Moody algebra is integrable if and only if $\lambda(\alpha_i^\vee)\geq 0$ for all $i=1,\cdots,n$"?
It should also be noted, that it've been earlier shown that "If $\alpha\in\Delta, w\in W$ then $w\alpha\in W$ and $\textrm{mult}(\alpha)=\textrm{mult}(w\alpha)$." Here $\Delta$ denotes the union of the positive and negative roots.
I've managed to prove that $V$ decomposes into a direct sum of finite-dimensional irreducible $\mathfrak{sl}_2$-modules.
Now in order to finish the proof, we need to justify that given a module $N$ in the $\mathfrak{sl_2}$-decomposition then $\dim N_\lambda=\dim N_{r_i\lambda}$. I think this i exactly the second lemma stated by Kac above. However we also need to justify that the weights have the form Joppy mentions. We also need to justify that $\lambda(\alpha_i^\vee)\in\mathbb{Z}$. This is where I'm still in doubt.
