  • Question: $ \mbox{How can we evaluate}\quad \sum_{n \geq 0}\left[{4^{n} \over \left(\, 2n + 1\,\right) \binom{2n}{n}}\right]^{2}{1 \over n + k}\quad \mbox{for general $k$ ?.} $
General methodology will be enough, but a closed-form is more preferable (if exists). Note that the previous problem, i.e. expressing binomial series in terms of MZVs, is solved via an alternative method (by user @pisco), so I simplified the question. For his method see here.
Infiniticism
  • 9,030
  • Can you do the case $n=0$: $$\int_0^1\ _3F_2\left( 1,1,1;\frac32,\frac32;x\right)\mathrm dx$$If not, then the general case is hopeless. – GEdgar Jul 04 '20 at 13:13
  • @User628759: as soon as you have some time, please have a look at the brief addendum at the bottom of my answer. – Jack D'Aurizio Aug 02 '20 at 13:43
  • @JackD'Aurizio Thank you for further explanation. Would you mind showing some references on theory of fractional operators (besides your paper)? – Infiniticism Aug 02 '20 at 14:30
    [1] J.-L Lavoie, T. J. Osler, and R. Tremblay, Fractional derivatives and special func- tions. SIAM Rev. 18 (1976), , 240–268.
    [2] T. J. Osler, A further extension of the Leibniz rule to fractional derivatives and its relation to Parseval’s formula. SIAM J. Math. Anal. 3 (1972), 1–16.
    – Jack D'Aurizio Aug 02 '20 at 14:55
    @JackD'Aurizio Much appreciation. – Infiniticism Aug 02 '20 at 14:57
    [3] L. Durand, Fractional operators and special functions. II. Legendre functions, J. Math. Phys. 44(5), 2266–2292 (2003) [4] Kiryakova, Generalized fractional calculus and applications – Jack D'Aurizio Aug 02 '20 at 14:57
The problem is equivalent to finding an explicit form for a $\phantom{}_4 F_3$ with half-integer parameters, since due to Rodrigues' formula and Euler's Beta function
$$\small \int_{0}^{1}\!\!\!P_n(2x-1)\sum_{m\geq 0}\left(\frac{4^m}{(2m+1)\binom{2m}{m}}\right)^2 x^m\,dx=\!\!\int_{0}^{1}\!\!\sum_{m\geq n}\left(\frac{4^m}{(2m+1)\binom{2m}{m}}\right)^2\binom{m}{n}x^{m}(1-x)^n\,dx $$ equals $$ \frac{16^n}{(2n+1)^3\binom{2n}{n}^3}\cdot\phantom{}_4 F_3\left(n+1,n+1,n+1,n+1;n+\tfrac{3}{2},n+\tfrac{3}{2},2n+2;1\right).$$ Not surprising since $\phantom{}_4 F_3(1^{(4)};3/2^{(2)},2;x)$ essentially is the primitive of $\phantom{}_3 F_2(1^{(3)};3/2^{(2)};x)$.
Let us see if we manage to crack the case $n=0$: $$ \sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{n+1}=\sum_{n\geq 0}\frac{4^n}{(2n+1)(n+1)\binom{2n}{n}}\int_{0}^{\pi/2}\left(\sin\theta\right)^{2n+1}\,d\theta $$ due to the Maclaurin series of $\arcsin(x)^2$ equals $$ \int_{0}^{\pi/2}\frac{x^2}{\sin x}\,dx = 2\pi\, C-\frac{7}{2}\zeta(3)$$ and I guess this method can be applied to other values of $n$, too.
For instance, for $n=1$ we have to find $$ \sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{16(n+1)^3}{(n+2)(n+3)(2n+3)^2} $$ which by partial fractions decomposition boils down to evaluating $$\small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{n+A+1},\quad \sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{2n+2B+1},\quad \sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{(2n+2B+1)^2} $$ for specific values of $A,B\in\mathbb{N}$. The situation is the same for $n>1$.
A small collection of relevant identities: $$ \small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{n+2} = -\frac{1}{4}+\frac{\pi}{4}+\frac{\pi C}{2}-\frac{7\zeta(3)}{8} $$ $$ \small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{n+3} = -\frac{11}{64}+\frac{13\pi}{64}+\frac{9\pi C}{32}-\frac{63\zeta(3)}{128} $$ $$ \small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{2n+1} = -\pi\,C+\frac{7}{2}\zeta(3) $$ $$ \small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{2n+3} = -1+\frac{\pi}{2} $$ $$ \small\sum_{n\geq 0}\left(\frac{4^n}{(2n+1)\binom{2n}{n}}\right)^2\frac{1}{(2n+3)^2} = -3+\pi. $$
It is relevant to point out that $$ \frac{4^n}{(2n+1)\binom{2n}{n}}=\frac{2n+3}{2n+2}\cdot\frac{4^{n+1}}{(2n+3)\binom{2n+2}{n+1}} $$ so reindexing (together with the identities in this answer) is extremely useful for dealing with series of the last kind.
There is also this nice result that John Campbell, Marco Cantarini and I proved through fractional operators: if $f\in(C^{\omega}\cap L^2)(0,1)$ is such that $$ f(x)=\sum_{n\geq 0}a_n x^n = \sum_{m\geq 0} b_m P_m(2x-1) $$ then $$ \sum_{n\geq 0}\frac{a_n}{(2n+1)^2\left[\frac{1}{4^n}\binom{2n}{n}\right]^2} = \sum_{m\geq 0}\frac{(-1)^m b_m}{(2m+1)^2}.$$
Partial fraction decomposition then shows that for any $k\in\mathbb{Z}^+$ your series is easily converted into a linear combination with rational coefficients of $1,\pi,\pi C$ and $\zeta(3)$ through the FL-expansion of $\frac{1}{x^k}\left(-\log(1-x)-\sum_{s=1}^{k-1}\frac{x^k}{k}\right)$, which can be derived from $$ -\log(1-x)=1+\sum_{m\geq 1}(-1)^m\left(\frac{1}{m}+\frac{1}{m+1}\right)P_m(2x-1) $$ and the method previously outlined here.
Jack D'Aurizio
  • 361,689
  • Hello Jack, could you share a copy of the paper Hypergeometry of the Parbelos? I requested a full-text on ResearchGate, but so far received no response. The paper might contain something interesting to me. – pisco Jul 06 '20 at 10:16
    @pisco: of course. This is not the definitive version, but it should do the job: https://www.dropbox.com/s/877b5cbczpccff8/Hypergeometry%20of%20the%20Parbelos%20v8.pdf?dl=0 – Jack D'Aurizio Jul 06 '20 at 11:12
    Thank you very much for the file. :) – pisco Jul 06 '20 at 11:29
