A carpenter worked on a job for 10 days and is then joined by an assistant. Together they can finish the job in 6 more days. The assistant can do the job in 30 days alone. How long does the carpenter need to work to do the job alone?
I’ve been trying to relate the time worked together and the time spent alone for the carpenter but without knowing the proportion of the job worked by each I just don’t know what to solve for. Is there a better way to complete this question?
    let C=fraction of job performed by carpenter in one day. let A=fraction of job performed by assistant in one day. You should be able to compute A directly. Then solve for C. I advise metacheating: assume that the problem is solvable with the info given, and go from there. – user2661923 Jan 03 '20 at 17:42
    I think I have been trying that from the start, however in order to solve for the carpenter’s fraction of work done I need to know the ratio of work done together and alone by the carpenter. My equation looks like this: 1/T = 1/30 + 1/C – QuickestCalcInTheWest Jan 03 '20 at 17:49
    30A=1 and 10C+6(A+C)=1 – user2661923 Jan 03 '20 at 17:51
    Oh, I get it now, thanks so much for the help. – QuickestCalcInTheWest Jan 03 '20 at 17:56
One way of approaching "working together problems" is to use the basic equation
$$ \text{distance} \; = \; \text{(rate)}\times \text{(time)} $$
where "distance" represents the work accomplished by working at a certain "rate" throughout a certain period of "time".
Let $r_C$ and $r_A$ be the rates at which the carpenter and assistant work, in units of job/day. The carpenter worked alone for $10$ days. Therefore, the amount of work the carpenter accomplished during these $10$ days (i.e. the "distance" the carpenter traveled in $10$ days) is
$$ \text{distance} \; = \; \text{(rate)}\times \text{(time)} \; = \; (r_C)(10) \; = \; 10r_C $$
Note that $10r_C$ is a certain "number of jobs", that number being less than $1.$ Therefore, the "number of jobs" (again, a number that is less than $1)$ that remains to be accomplished after these $10$ days of work by the carpenter is $1 - 10r_C$ (i.e. $1$ job $-$ $10r_C$ job). Since we are told that this remaining "number of jobs" can be accomplished by the carpenter and assistant working together for a total of $6$ days (i.e. when the work is performed at the rate of $r_C + r_A$ job/hour for a total of $6$ days), then using (distance) = (rate)(time) we get
$$ 1 - 10r_C \; = \; (r_C + r_A)(6) $$
We are given that the assistant can complete the entire job in $30$ days, so $r_A$ equals $\frac{1}{30}$ jobs/day. If this last observation is not clear, then use (distance) = (rate)(time) again: We have $(1 \, \text{job}) = (r_A \; \text{jobs/day})(30 \; \text{days}),$ which when solved for $r_A$ gives $r_A = \frac{1}{30}.$
Plugging this numerical value of $r_A$ into the last displayed equation gives
$$ 1 - 10r_C \; = \; \left(r_C + \frac{1}{30}\right)(6) $$
$$ 1 - 10r_C \; = \; 6r_C + \frac{6}{30} $$
$$ 1 - \frac{6}{30} \; = \; 6r_C + 10r_C $$
$$ 1 - \frac{1}{5} \; = \; 16r_C $$
$$ \frac{4}{5} \; = \; 16r_C $$
$$ r_C \; = \; \frac{4}{5} \cdot \frac{1}{16} \; = \; \frac{1}{5} \cdot \frac{1}{4} \; = \; \frac{1}{20} $$
Therefore, the carpenter works at a rate of $\frac{1}{20}$ jobs per day, so it will take the carpenter $20$ days to complete the job working alone. If this final result is not clear from "works at a rate of $\frac{1}{20}$ jobs per day", then use (distance) = (rate)(time) again: We have (1 job) = $\left(\frac{1}{20} \, \text{job/day}\right)(t \, \text{days}),$ which when solved for $t$ gives $t = 20.$
There are quicker ways of getting the answer to this particular problem, but I've found this method to be useful when you don't immediately see what to do, namely the method of taking things step-by-step using the (distance) = (rate)(time) equation whenever appropriate (i.e. whenever for a certain situation you know two of the three unknowns "distance", "rate", "time").
If the assistant could do the job in thirty days alone, then he could do one fifth of the job in six days [because six is one fifth of thirty]. That means that the carpenter spent sixteen days completing four fifths of the job. But this implies that he could perform one fifth of the job in four days, and therefore the entire job by himself in twenty days.
John Joy
  • 8,060
Let the carpenter can complete the whole work alone in $x$ days.
Therefore, the fraction of the work completed in $10$ days by the carpenter $= \frac{10}{x}$ The fraction of the work completed in further $6$ days by the carpenter $= \frac6{x}$.
The fraction contributed by the assistant $= \frac6{30} = \frac15$.
The work gets completed in these fractions. Therefore, $\frac{10}x + \frac6{x} + 1/5 = 1$ or, $\frac{16}x = 1 - \frac15 = \frac45$ or, $$x = 16 \cdot \left(\frac54\right) = 20$$
Siong Thye Goh
  • 153,832
