I need to solve with basic methods this simple Shallow Water Model:
$$\begin{bmatrix}h\\ hv\end{bmatrix}_t+\begin{bmatrix}hv\\ hv^2+\frac{1}{2}gh^2\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
where $h$ is the height of the water, $v$ is the horizontal velocity of the fluid and $g$ is the gravitational constant.
Writing in quasilinear form, I've got
$$\begin{bmatrix}h\\ hv\end{bmatrix}_t+\begin{bmatrix}0&1\\ gh-v^2&2v\end{bmatrix}\begin{bmatrix}h\\ hv\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
The Jacobian can be diagonalized as $J=RDR^{-1}$ where
$$R=\begin{bmatrix}\dfrac{1}{v-\sqrt{gh}}&\dfrac{1}{v+\sqrt{gh}}\\ 1&1\end{bmatrix}$$
$$R^{-1}=\begin{bmatrix}\dfrac{v^2-gh}{2\sqrt{gh}}&\dfrac{1}{2}-\dfrac{v}{2\sqrt{gh}}\\ \dfrac{gh-v^2}{2\sqrt{gh}}&\dfrac{1}{2}\bigg(\dfrac{v}{\sqrt{gh}}+1\bigg)\end{bmatrix}$$
$$D=\begin{bmatrix}v-\sqrt{gh}&0\\0&v+\sqrt{gh}\end{bmatrix}$$
I've done the change of variables
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}=R^{-1}\begin{bmatrix}h\\ hv\end{bmatrix}$$
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}=\begin{bmatrix}\frac{h}{2}(v+\sqrt{gh})\\ \frac{h}{2}(v-\sqrt{gh})\end{bmatrix}$$
Geting the system
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_t+\begin{bmatrix}v-\sqrt{gh}&0\\0&v+\sqrt{gh}\end{bmatrix}\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
ie
$$\overline{h}_t+(v-\sqrt{gh})\overline{h}_x=0\\ \overline{k}_t+(v+\sqrt{gh})\overline{k}_x=0$$
Trying to solve this conservation laws by the characteristic method, I've got to the first
$$x(t)=(v_0(x_0)-\sqrt{gh_0(x_0)})t+x_0\qquad (i)$$
and to the second
$$x(t)=(v_0(\overline{x}_0)+\sqrt{gh_0(\overline{x}_0)})t+\overline{x}_0\qquad (ii)$$
where $v_0,h_0$ are the initial conditions.
To find the solution at time $(x,t)$, I need to solve $(i)$ for $x_0$ and take $\overline{h}(x,t)=\overline{h}_0(x_0)$ and solve $(ii)$ for $\overline{x}_0$, taking $\overline{k}(x,t)=\overline{k}_0(\overline{x}_0)$.
The solution in time $(x,t)$ may be the solution of the system
$$\begin{bmatrix}\overline{h}_0(x_0)\\ \overline{k}_0(\overline{x}_0)\end{bmatrix}=\begin{bmatrix}\frac{h}{2}(v+\sqrt{gh})\\ \frac{h}{2}(v-\sqrt{gh})\end{bmatrix} $$
That is
$$hv(x,t)=\overline{h}_0(x_0)+\overline{k}_0(\overline{x}_0)$$
$$h(x,t)=\bigg(\dfrac{\overline{h}_0(x_0)-\overline{k}_0(\overline{x}_0)}{\sqrt{g}}\bigg)^{2/3}$$
Or better
$$hv(x,t)=\frac{h_0(x_0)(v_0(x_0)+\sqrt{gh_0(x_0)})+h_0(\overline{x}_0)(v_0(\overline{x}_0)-\sqrt{gh_0(\overline{x}_0)})}{2}$$
$$h(x,t)=\bigg(\dfrac{h_0(x_0)(v_0(x_0)+\sqrt{gh_0(x_0)})-h_0(\overline{x}_0)(v_0(\overline{x}_0)-\sqrt{gh_0(\overline{x}_0)})}{2\sqrt{g}}\bigg)^{2/3}$$
I would like to know:
1) If my idea is correct (mainly about characteristics: is it valid? I think there is troubles with this part)
2) If these calculus are sufficient to "solve" the system. In other words, what mean the "solution" of the system? The question that I am dealing is only the following:
Find the solution to the model.
I think this is something vague once I don't have any data. What do you understand as the "solution of the system"?
3) And if the characteristics crosses or occur some problem with this method? Or if (i) and (ii) don't have solutions? With some simulations that I've tried the equations (i) and (ii) don't had solutions for a great number of points $(x,t)$. Without the initial conditions, how can I know about possible troubles?
Many thanks.
Edit
If we wish to study waves with very small amplitude, then we can linearize these equations around some constant state $(\hat{h},\hat{h}\hat{v})$ to obtain a linear system.
$$\begin{bmatrix}h\\ hv\end{bmatrix}_t+\begin{bmatrix}0&1\\ g\hat{h}-\hat{v}^2&2\hat{v}\end{bmatrix}\begin{bmatrix}h\\ hv\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
Getting the system
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_t+\begin{bmatrix}\hat{v}-\sqrt{g\hat{h}}&0\\0&\hat{v}+\sqrt{g\hat{h}}\end{bmatrix}\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
where
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}=R^{-1}\begin{bmatrix}h\\ hv\end{bmatrix}=\begin{bmatrix}\dfrac{\hat{v}^2-g\hat{h}}{2\sqrt{g\hat{h}}}&\dfrac{1}{2}-\dfrac{\hat{v}}{2\sqrt{g\hat{h}}}\\ \dfrac{g\hat{h}-\hat{v}^2}{2\sqrt{g\hat{h}}}&\dfrac{1}{2}\bigg(\dfrac{\hat{v}}{\sqrt{g\hat{h}}}+1\bigg)\end{bmatrix}\begin{bmatrix}h\\ hv\end{bmatrix}$$
The solution is
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}(x,t)=\begin{bmatrix}\overline{h}_0(x-(\hat{v}-\sqrt{g\hat{h}})t)\\ \overline{k}_0(x-(\hat{v}+\sqrt{g\hat{h}})t)\end{bmatrix}$$
Or better
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=R\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}(x,t)$$
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=\begin{bmatrix}\dfrac{1}{\hat{v}-\sqrt{g\hat{h}}}&\dfrac{1}{\hat{v}+\sqrt{g\hat{h}}}\\ 1&1\end{bmatrix}\begin{bmatrix}\overline{h}_0(x-(\hat{v}-\sqrt{g\hat{h}})t)\\ \overline{k}_0(x-(\hat{v}+\sqrt{g\hat{h}})t)\end{bmatrix}$$
For instance, let take $\hat{h}=1$ and $\hat{v}=0$, considering $g=1$ (in some dimension).
So,
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}=\begin{bmatrix}\dfrac{-1}{2}&\dfrac{1}{2}\\ \dfrac{1}{2}&\dfrac{1}{2}\end{bmatrix}\begin{bmatrix}h\\ hv\end{bmatrix}=\begin{bmatrix}\dfrac{(hv-h)}{2}\\ \dfrac{(h+hv)}{2}\end{bmatrix}$$
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_t+\begin{bmatrix}-1&0\\0&1\end{bmatrix}\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}_x=\begin{bmatrix}0\\ 0\end{bmatrix}$$
The solution is
$$\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}(x,t)=\begin{bmatrix}\overline{h}_0(x+t)\\ \overline{k}_0(x-t)\end{bmatrix}=\begin{bmatrix}\dfrac{(h_0v_0-h_0)(x+t)}{2}\\ \dfrac{(h_0v_0+h_0)(x-t)}{2}\end{bmatrix}$$
Or better
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=R\begin{bmatrix}\overline{h}\\ \overline{k}\end{bmatrix}(x,t)=\begin{bmatrix}-1&1\\1&1 \end{bmatrix}\begin{bmatrix}\dfrac{(h_0v_0-h_0)(x+t)}{2}\\ \dfrac{(h_0v_0+h_0)(x-t)}{2}\end{bmatrix}$$
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=\begin{bmatrix}\dfrac{(-h_0v_0+h_0)(x+t)+(h_0v_0+h_0)(x-t)}{2}\\ \dfrac{(h_0v_0-h_0)(x+t)+(h_0v_0+h_0)(x-t)}{2}\end{bmatrix}$$
Taking $v_0\equiv0$ and $h_0=1+\frac{2}{5}e^{-5x^2}$ as in [1], we have
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=\begin{bmatrix}\dfrac{h_0(x+t)+h_0(x-t)}{2}\\ \dfrac{-h_0(x+t)+h_0(x-t)}{2}\end{bmatrix}$$
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=\begin{bmatrix}\dfrac{1+\frac{2}{5}e^{-5(x+t)^2}+1+\frac{2}{5}e^{-5(x-t)^2}}{2}\\ \dfrac{-1-\frac{2}{5}e^{-5(x+t)^2}+1+\frac{2}{5}e^{-5(x-t)^2}}{2}\end{bmatrix}$$
$$\begin{bmatrix}h\\ hv\end{bmatrix}(x,t)=\begin{bmatrix}1+\frac{1}{5}(e^{-5(x+t)^2}+e^{-5(x-t)^2})\\ \frac{1}{5}(-e^{-5(x+t)^2}+e^{-5(x-t)^2})\end{bmatrix}$$
[1] CROWHURST, Peter. Numerical Solutions of One-Dimensional Shallow Water Equations. Australian Mathematical Science Institute, School Of Computing And Mathematics, Charles Sturt University, Feb. 2013.
