Let $$f(x)=\sum_{k=2}^{10}(\lfloor kx \rfloor -k \lfloor x \rfloor),$$ where $\lfloor r \rfloor$ denotes the greatest integer less than or equal to $r$. How many distinct values does $f(x)$ assume for $x \ge 0$?
I first started out this problem with the memory that once a math teacher told me that $x = \lfloor x \rfloor + \{ x \}$ where $\{ x \}$ is the fractional part of $x$. I plug this in and get we have
$$f(x) = \sum_{k=2}^{10} (\lfloor k \lfloor x \rfloor +k \{ x \} \rfloor - k \lfloor x \rfloor)$$
The function can then be simplified into
$$f(x) = \sum_{k=2}^{10} ( k \lfloor x \rfloor + \lfloor k \{ x \} \rfloor - k \lfloor x \rfloor)$$
which becomes
$$f(x) = \sum_{k=2}^{10} \lfloor k \{ x \} \rfloor$$ I don't know how to continue.
Am I on the right track? If so, how should I continue? If not, what path should I take?
Also, if you are nice, could you please also help me on this problem($N$'s base-5 and base-6 representations, treated as base-10, yield sum $S$. For which $N$ are $S$'s rightmost two digits the same as $2N$'s?)?
Thanks!
Max0815
Max0815
  • 3,584
I solved it. Yay thanks Jens S. for helping me!
Max0815
  • 3,584
