I was reading through this answer to a question about the lower bound of a least common multiple.
The question is about showing that:
$$\text{lcm}(1,2,\dots,n) > 2^n$$
I was not clear on one step in the answer provided.
Here are the steps that I understand:
(1) I am clear on the definition of $I_{m,n}$ where $1 \le m \le n$:
$$I_{m,n}=\int_0^1x^{m-1}(1-x)^{n-m}dx = \sum_{r=0}^{n-m}\frac{a_r}{m+r}$$ where each $a_r \in \mathbb{Z}$
(2) I am clear that if $\displaystyle\ell_n = \text{lcm}(1,2,\dots,n)$ that:
$$\displaystyle\ell_n I_{m,n} \in \mathbb{Z}$$
I am unclear when Integration by Parts is applied.
(3) The answer states:
Now it can easily be seen that $I_{m,n} = \dfrac{1}{m{n\choose m}}$
Which follow from integration by parts or reduction formulae.
Could someone explain to me how this last step follows from the first two?
Larry Freeman
  • 10,189
    I'm pretty sure the integral can be written as the beta function, which can be written in terms of the gamma function, which can be written in terms of factorials – Seth Nov 04 '18 at 00:23
  • Thanks for the tip. I'm not familiar with the beta function. I'll review. I am familar with the gamma function. If you can write the equality as the answer, I will be glad to review and accept if it is clear to me. – Larry Freeman Nov 04 '18 at 00:31
  • @seth. Cool stuff: https://en.wikipedia.org/wiki/Beta_function – Larry Freeman Nov 04 '18 at 00:32
  • Thanks. I'll update the question so it is correct and accept your answer. – Larry Freeman Nov 04 '18 at 02:52
$I_{m,n}=\int_0^1 x^{m-1}(1-x)^{n-m+1-1}dx=B(m,n-m+1)=\cfrac{\Gamma(m) \Gamma(n-m+1)}{\Gamma(n+1)}$, which, if n and m are positive integers, is equal to $\cfrac{(m-1)!(n-m)!}{n!}=\cfrac{1}{m{n \choose m}}$, as claimed
Seth
  • 534
  • 14
